Cabin filter change
Revision as of 12:27, 10 January 2021 by Bosanek (talk | contribs) (Added a new picture)
It appears that most people do not realize that the Jimny has a cabin / pollen filter, or at least has the facility for a cabin filter.
Most manuals never refer to it, even in the OEM Service Guide.
A lot of people, particularly those who drive off-road, are tired of the clouds of leaves that hit you in the face when you open the fascia vents. Fitting a cabin filter is straight forward once you know where it is (supposed to be) hidden.
If your Jimny already has a cabin filter installed (but you have not been aware of it), the filter is probably heavily clogged.
Used old cabin filter with charcoal particles
  • This is an example of a five year old (heavily used) cabin filter of unknown manufacturer, which was removed from a Jimny 3.
    • This is a filter which contains charcoal particles, so it is normal to look "dirty" / greyish, but not this much.
  • That picture was unfortunately taken just after the leaves and grit were brushed off off from the filter.
  • The weight of that used dirty filter was around 800 grams!
Required parts
The filter itself
General info
When selecting a filter, consider what types of pollutants concern you the most:
  • Ordinary paper / fiber filters (the most common products) filter only dust and some pollen.
  • Filters which also contain carbon (charcoal) particles filter various odors, smells, gases and chemical vapors as well.
  • The "biofunctional" / "antibacterial" etc. filters filter mold, bacteria, spores etc. as well.
Bear in mind that filters from different manufacturers have different quality, which consists of two factors:
  • How well they filter what they filter.
    • In other words - how small dust and pollen particles, which types of vapors and gases and how much of them.
  • How much of the pollutants they can filter before they get clogged and become an obstruction to expected air flow into the cabin.
    • In other words - what is their expected operational life time.
Original Suzuki filters
The part numbers of Suzuki's genuine cabin / pollen filters for Jimnys are:
  • 95860-81A00
  • 95860-81A01
  • 95860-81A10
All three should be mutually compatible (same dimensions etc.). A guess is that the differences are probably "only" in the filtering capability.
Required dimensions for a compatible filter are:
  • Length : 213-217 mm
  • Width : 183-188 mm
  • Height : 20 mm
Non-charcoal aftermarket filters
Some of many compatible non-charcoal aftermarket replacements:
Brand new Blue Print ADK82502 cabin filter - two-piece specimen with a bit of carbon particles
Aftermarket filters with charcoal particles
Compatible aftermarket filters which truly contain proper charcoal (carbon) particles in a significant amount are quite rare (and usually significantly more expensive).
Known filters with charcoal particles (add others if you find them):
  • Aster AS2547
    • Model AS2547F is the ordinary paper filter - do not mix them up!
    • The manufacturer claims that this filter model is compatible for Jimnys, but specifies its dimensions as 213 mm x 194 mm x 20 mm.
      • It should still fit, but someone should verify in practice.
  • Corteco 80001447
    • The manufacturer claims it is a charcoal filter, but the filter does not appear significantly "sooty" in the pictures below.
    • Model 80001446 is the ordinary paper filter - do not mix them up!
  • Magneti Marelli 154703714750
  • Masuma MC-1054CL
    • Model MC-1054 is the ordinary paper filter - do not mix them up!
  • Meyle 33-12 320 0001
    • This filter appears to be discontinued by its manufacturer (not listed in their catalogue any more) and only the ordinary paper model 33-12 319 0001 remains in production.
      • Good luck finding the discontinued specimens!
  • Nitto F801
    • Model F805 is the ordinary paper filter - do not mix them up!
  • RAF RF001HYX
    • According to this Russian user report, this is a poor quality filter (poor filtering capacity).
  • Sivento G690
    • Model P690 is the ordinary paper filter - do not mix them up!
  • Vic AC-931EX
    • Model AC-931E is the ordinary paper filter - do not mix them up!
  • Zaffo Z547 / 547
    • Model ZF547 / 547F is the ordinary paper filter - do not mix them up!
  • Zero WZ1547
    • Model WZ1547F is the ordinary paper filter - do not mix them up!
New cabin air filter Aster AS2547 (representative catalogue image)
New cabin air filter Nitto F801
New cabin air filter Vic AC-931EX
New cabin air filter Zaffo Z547 (representative catalogue image)
New cabin air filter Zero WZ1547
Additional notes and warnings
  • The appearance and construction of a cabin filter may vary slightly from one manufacturer to another.
  • Some filters are one-part, like in the picture of a dirty filter above.
  • Some are two-part, and the parts can be glued or taped together (like in the other picture above).
  • Always make sure to check the dimensions of a filter when buying.
  • The quality and capability of a filter may vary significantly from one manufacturer or model to another.
  • The main difference is in the presence or absence of various filtering elements which filter out certain things.
    • For example, a filter with or without carbon (charcoal) particles.
      • Such filters usually look "dirty" like having a bit of soot in them.
  • It is highly recommended to use a filter with activated carbon particles, but be prepared to pay a higher price.
  • Blue Print's ADK82502 filter used to be a two-part construction with embedded carbon (charcoal) particles.
  • However, there have been recent reports of "sightings" of the same filter model which contained a lot less charcoal particles, and also of a plain ordinary paper filter in a single-part case.
  • So, if buying this filter model (or any other filter model for that matter), double-check with the seller on what exact filter is in the box!
  • Two "same" cabin filters Blue Print ADK82502.
  • The amount of carbon particles in the newer (left) filter is significantly less than in the older (right) filter.
  • There have also been confirmed sightings of this filter model which had a pure white color, without a single carbon particle in it.
  • Obviously the amount of carbon particles in this filter model varies widely from batch to batch!
Suzuki Jimny 3 - two cabin filters Blue Print ADK82502 and one cabin filter Mahle LA 95 - A01.jpg
  • TOP: Filter Mahle LA 95 - ordinary paper, single-piece construction.
  • LEFT: Blue Print ADK82502, newer production date.
  • RIGHT: Blue Print ADK82502, older production date.
Filter cover
Genuine cabin filter cover
  • You may wish to consider buying a spare cabin filter cover at the same time.
  • The part number of Suzuki's genuine cabin / pollen filter cover for Jimnys is: 95423-81A01
  • The suitable cover is also offered in BigJimny Shop.
Warning Icon.pngIt is common to break the filter cover when removing it as the plastic becomes brittle.
Changing / Installing a cabin filter
  • Assorted screwdrivers or blade
Warning Icon.pngI cannot emphasis too strongly how easy it is to break the old cover!
Installation
Passenger footwell
  • Here is the filter cover, up underneath the dashboard on the passenger side of the vehicle
Here is the cover in the footwell
Open brake caliper
  • First remove the glovebox.
  • This is done by flexing the sidewalls so the plastic retaining lugs can drop past the edge of the fascia.
  • Lower the whole glovebox away.
  • I am using a screwdriver with the end protected by a cloth to stop it marking the fascia, as I use it to prise away the retaining lugs.
Cabin filter cover retaining clips
Glovebox dropped open
  • The filter cover is retained by small clips on the end.
  • The tip of the scewdriver points to where the clip is (hidden).
Using blade to prise clip
  • Warm the plastic filter cover.
  • Either use a hairdrier or allow the car's own heater to warm the car (on re-circulate setting).
  • If the plastic is cold it is more likely to fracture.
  • Insert a small blade into the filter retaining lugs and gently prise it away from the edge of the moulded catches on the heater body.
  • Do this a bit at a time alternating front and back.
Inserting the cabin filter
  • If you have a UK Jimny, you are more than likely to find an empty hole now (full of bits of leafs).
  • Simply insert the cabin filter.
Press the new cover on
  • Gently press the filter cover back into place.
Broken!!
  • Don't think that you will be immune to breaking the filter cover - here is mine!
Additional reading
Page last edited on 10/01/2021 by user Bosanek
