Gearbox, Differential and Transfer Box Ratio Information
Date | Country | Engine | Gearbox | Gear 1 | Gear 2 | Gear 3 | Gear 4 | Gear 5 | Transfer Box | High | Low | Final Drive |
1998 | UK/EU | G13B | Manual | 3.652 | 1.947 | 1.423 | 1.000 | 0.864 | Manual | 1.320 | 2.145 | 3.909 |
1998 | UK/EU | G13B | Auto | 2.962 | 1.515 | 1.000 | 0.738 | N/A | Manual | 1.320 | 2.145 | 4.090 |
2001 | UK/EU | M13A | Manual | 3.652? |
1.947? |
1.423? |
1.00 | 0.864? |
Manual | 1.32 | 2.145 | 3.909 |
2001 | UK/EU | M13A | Auto | 2.962? |
1.515? |
1.000? |
0.738? |
N/A | Manual | 1.32 | 2.145 | 4.090 |
2005+ | UK/EU | M13AVVT | Manual | 4.425 | 2.304 | 1.674 | 1.190 | 1.000 | Electric | 1.00 | 2.002 | 4.300 |
2005+ | UK/EU | M13AVVT | Auto | 2.875 | 1.568 | 1.000 | 0.695 | N/A | Electric | 1.32 | 2.643 | 4.090 |
2005+ | EU | K9K | Manual | 4.246 | 2.357 | 1.695 | 1.242 | 1.00 | Electric | 1.00 | 2.002 | 3.416 |
2000 | JP | K6A | Manual | 4.031 | 2.391 | 1.513 | 1.00 | 0.790 | Manual | 1.320 | 2.145 | 5.375 |
2000 | JP | K6A | Auto | 2.902 | 1.515 | 1.00 | 0.736 | N/A | Manual | 1.320 | 2.145 | 5.375 |
2010 | JP | K6A | Manual | 5.106 | 3.107 | 1.908 | 1.254 | 1.000 | Manual | 1.320 | 2.643 | 4.300 |
2010 | JP | K6A | Auto | 2.875 | 1.568 | 1.000 | 0.696 | N/A | Electric | 1.320 | 2.643 | 5.375 |
See below for some worked examples: (test)
2005 VVT manual gearbox Jimny, engine at 4000 RPM and in 5th gear High Ratio
Gearbox input = 4000 RPM
Gearbox ratio = 1
Gearbox output = 4000 RPM
Transfer box input =4000 RPM
Transfer box ratio = 1
Transfer box output = 4000 RPM
Diff input = 4000 RPM
Diff ratio (final drive) = 4.3
Diff output = 465 RPM
Wheel input = 465 RPM
Wheel diameter = 28 inches
Road speed = 77.7 miles per hour
2005 VVT manual gearbox Jimny, engine at 3000 RPM and in 1st gear Low Ratio
Gearbox input = 3000 RPM
Gearbox ratio = 4.425
Gearbox output = 678 RPM
Transfer box input =678 RPM
Transfer box ratio = 2.002
Transfer box output = 338.6 RPM
Diff input = 338.6 RPM
Diff ratio (final drive) = 4.300
Diff output = 78.5 RPM
Wheel input = 78.5 RPM
Road speed = 1.5 miles per hour
Note: For the road speed calc you can use your maths from school or a web calculator - www.4qd.co.uk/road-speed-calculator/----
Page last edited on 15/01/2018 by user Mlines
