- 1 Introduction
- 2 Engaging and disengaging 4WD-H and 4WD-L
- 3 Using 4WD-H or 4WD-L on hard surfaces
- 4 Negotiating hairpin bends in 4WD modes
- 5 Using the hand brake in 4WD modes
- 6 Using 2WD / 4WD-H / 4WD-L buttons
- 7 Driving (im)properly
- 8 Lending the vehicle
- 9 Overloading the vehicle
- 10 Transporting driver + four passengers
- 11 Towing or recovering heavier vehicles
- 12 Towing a Jimny by another vehicle
- 13 Proper tyre pressures
- This article contains some important practical tips, notes and warnings when using and operating a Jimny.
- They can:
- Ease your life,
- You probably know that you can (dis)engage between 2WD and 4WD-H on the move (and with the steering wheel pointing straight).
- You might have also witnessed a loud "bang" from the front wheel vacuum locking hubs when disengaging, or even from a transfer case (that's already a serious bang!).
- A bang occurs when the transmission is disengaging under tension and this certainly wears it excessively.
- Then disengage.
Beware: If you (dis)engage between 2WD and 4WD-H while applying a significant throttle, a wheel slippage might occur during the shifting phase, and this is very bad for the transmission system (written in Jimny's Owner's manual).
- When shifting from high range to low range and vice versa, make sure that the vehicle is completely stationary first!
- While it is technically possible for a skilled driver to shift while the vehicle is going rather slowly (you might have discovered that by a chance), you are taking a big gamble while doing so!
Jimny has a part-time 4WD transmission system without a center differential.
- Dry tarmac roads;
- Dry grass;
Many people make a mistake of thinking that wet tarmac roads are slippery and turn on 4WD. Well they are slippery, but not nearly enough for Jimny's 4WD system.
- Warning: During this process, do not turn the steering wheel while stationery. Turn it only while in motion.
Exception to this rule are vehicles where the hand brake actually brakes the gears in the gear box or in the transfer box, instead of the typical design where the hand brake brakes the discs or drums in the rear wheels. Jimnys have the "typical" design.
Explanation of the incompatibility:
- Vehicles with part-time 4WD transmissions (like the Jimny) do not have a center (inter-axle) differential.
- For Jimnys, this is valid in both 4WD-H and 4WD-L transmission modes.
Conclusions:
- The best way to damage a part-time 4WD transmission is to use the hand brake to "spin" the vehicle around "fast 'n furious" style on a hard throttle in 4WD mode (this is usually tempting to perform on snow). This maneuver will certainly make a lot of cash bills spin out of your wallet!
- There is an annoying and potentially dangerous issue with some (early) Jimnys which have electrically ("push-button") controlled transmission (2005 - probably around 2008).
- The 4WD controller in later Jimnys (probably from around 2008 on) has a corrected design to acknowledge a transmission control button press only if the button is kept pressed for at least 2 seconds or so.
- In practice with those earlier Jimnys, it is very easy to accidentally (inadvertently) touch a 2WD or 4WD-H button when fiddling with the other nearby controls on the dashboard, or when fiddling with your passenger.
- It also tends to happen when a female passenger operates male driver's engagement/relief lever during driving.
- There is no known remedy for this issue on earlier push-button Jimnys, except that both the driver and the co-driver be very careful and aware of this.
- In fact there is an (expensive) remedy - replace its 4WD control computer with a 4WD control computer from a newer Jimny.
Here is a video of the sequence on a 2005 VVT Jimny:
- Do not drive the Jimny on the road as you would drive an ordinary passenger car.
- Drive the Jimny correctly and it might even be more entertaining than driving an ordinary vehicle.
- In fact, many motoring journalists commented that Jimny is very entertaining and joyful to drive when they test-drove the Jimny in the early 2000s!
- Now the new generation X of journalists spit on the same vehicle, just because they don't know how to drive it.
Driving Jimny properly means that you should drive defensively, especially in bends. Drive smoothly and observe ahead, so you can timely adjust for changing conditions.
- Don't stomp on the throttle in a bend or when exiting it. Otherwise, you might get a free rollercoaster ride.
- Watch out for road undulations and slow down when you approach them. Otherwise, brace yourself.
- When reversing uphill, be easy on the throttle to avoid wheel spin. This is common with any Mercedes or BMW vehicle for example.
- If you see that you are driving too fast on an imperfect road (the vehicle wobbles like a jelly or wants to fly off), then slow down damn it! It's an all-terrain vehicle, not a roadster!
If you drive the Jimny like an ordinary modern vehicle:
- The way that idiot drove that Jimny in the video is actually how to drive a roadster-class vehicle on the road!
- Also bear in mind that Jimny, like most proper all-terrain vehicles, are significantly more susceptible (compared to "on-road" cars) to end up rolled over in collisions and collision evasion situations, and also in situations where vehicle starts to spin out of control (for example on a snowy road).
For example, observe this compilation of crashes and accidents on roads in winter conditions, and imagine how would your Jimny fare in some of them:
Lending the vehicle
It is very dangerous to lend a Jimny to someone who is not trained to drive it. Read the chapter on proper driving for details why.
There are three risks:
- They will intentionally or accidentally operate the 4WD controls and damage the transmission by driving it improperly (especially risky with newer Jimnys with "push-button" transmission controls).
- Jimnys have unusually small weight carrying ability for a proper all-terrain vehicle - it is just around 330 kg in total.
- Jimny was made to transport four people at most, including the driver.
- Some comparative examples
- Ventilation or air conditioning will be severely restricted, because there will be hardly any free space in the cabin for the air to circulate. Ever listened to the song "Steamy windows" by Tina Turner? Combine that with the song "I can't stand the rain" from the same singer!
- Forum user Bosanek indeed once transported four male adult passengers (with full mountaineering equipment) in his Jimny in an emergency situation for 80 kms, all on winding alpine tarmac roads.
- How?
- That's how.
- Jimny weights just slightly over one tonne, and Samurai is even lighter than that.
- Know the case that a drowning person tends to drown their savior? Well a similar thing is the issue here. Read on.
- Jimny with the Big Boys. Those goliaths can tow a bunch, 'and then some'. Jimny can't!
An example:
- A Suzuki Samurai tried to tow a Toyota 4Runner loaded with mountaineering equipment (cca 2000 kg total weight) up a relatively short, packed snowy uphill track.
- The Samurai had easily went up that section alone, and 4Runner managed to climb half way up several times.
- So Samurai started towing the 4Runner uphill.
- First the 4Runner lost the grip on the last 10 meters of the way, and almost immediately Samurai lost it as well.
- Samurai was pulled back, turned aside and then rolled over onto 4Runner's bonnet.
Conclusion:
- Jimny is relatively safe to use as a recovery vehicle for vehicles of similar weight (approximately up to 1500 kg).
- If the stranded vehicle weights between 1500 kg and 2000 kg, you are in the yellow zone. Assess the situation (slope, gradient, terrain, etc.). Proceed with caution.
- If the stranded vehicle weights more than 2 tonnes, that you are in a bright orange or a scorching red zone (depending on slope, gradient, terrain, driver in that vehicle, etc!). Try to help them any way you can except towing them if possible!
- Remember, the weight of the vehicle is not just its stock weight from the brochure. Check if it carries additional cargo or equipment (typical with 4WD vehicles).
- All these advices and cautions are valid when towing any vehicle (it does not matter if the towed vehicle has 4WD transmission or not).
- Even if they do not know the weight of their vehicle (or if you notice that they are just guessing it), try to "google it out" on the spot or call someone to do it for you. Assess the situation!
If your Jimny has a fault due to which it has to be towed on a certain length of road, you must take special precautions in order to avoid critical damage to the transmission when towing it!
- However, this can be done only when the gear box is in neutral and only after making certain that vehicle is truly in 2WD(-H) transmission mode (both front wheel hub heads unlocked, front propeller shaft disconnected from the 4WD mechanisms in the transfer box).
Аll information in this chapter has been written based upon Suzuki's official guidelines for towing a Jimny as written in vehicle's official Owner's manual - section 7 about towing.
Page last edited on 12/12/2017 by user Bosanek
