Changing the Kingpin Bearings
- Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Changing the bearings
- Assorted screwdrivers
- Circlip pliers (External)
- A ball joint splitter
- 1" Imperial Socket
The Video
Removing the Caliper and pads
Removing the Brake Disc
Dismantling the Hub
Undo the nuts on the steering joints, if the joint rotates then put a jack under the joint and lift the car slightly to lock the joint. Using a splitter, split the steering joints (two to do on the passenger side and one on the drivers side – UK). <br clear=all)
Finally, release the KingPin bolts themselves. There are two sets, top and bottom and they must not be mixed up so you can see in the picture that I have marked them up with a letter T. If you are doing both sides at once then do not mix them across either!. <br clear=all)
