King pin bearing change
Revision as of 20:25, 12 May 2016 by Mlines (talk | contribs)
Changing the Kingpin Bearings
Warning Icon.pngThis page is a work in progress - please do not edit at this stage.
  • Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Leaking front swivel
Changing the bearings
* Standard metric sockets and spanners
* Assorted screwdrivers
* Circlip pliers (External)
* An E10 Torx socket for the Vacuum Hub Bolts
* A ball joint splitter
The Video
Removing the Caliper and pads
Jimny Front Caliper
Note Icon.pngClick on images to make them larger
Unbolting the caliper
Open brake caliper
Removing the brake pads
Removing the Brake Disc
Carrier bolt
Caliper tied to Spring
Disc removal using bolt
