Changing the Kingpin Bearings
- Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Changing the bearings
The Video
Removing the Caliper and pads
Removing the Brake Disc
My disk appeared to be ok on the visible side but the rear showed some bad
wear so I will change them as part of this job.
