King pin bearing change
Revision as of 19:55, 12 May 2016 by Mlines (talk | contribs)
Changing the Kingpin Bearings
Warning Icon.pngThis page is a work in progress - please do not edit at this stage.
  • Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Changing the bearings
The Video
Removing the Caliper and pads
Jimny Front Caliper
Note Icon.pngClick on images to make them larger
Unbolting the caliper
Open brake caliper
Removing the brake pads
The pads are retained by small spring clips, a simple pull on the pads (horizontally away from the disk) should remove them (or gently prise out the pads with a small screwdriver - do not remove the spring clips).
Removing the Brake Disc
Carrier bolt
Caliper tied to Spring
Disc removal using bolt
