King pin bearing change
Revision as of 15:10, 12 May 2016 by Mlines (talk | contribs) (Created page with "= Changing the Kingpin Bearings = == Introduction == If you off-road a Jimny (or any of the Suzuki classic 4wd vehicles) then this is a job you will become familiar with. It...")
  • Steering Shimmy
  • Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Changing the bearings
First of all secure the car, release the wheel nuts and jack up the car and remove the road wheel. This then reveals the brake caliper, this is the passenger side (nearside) caliper (UK).
