- 1 Introduction
- 2 Typical points susceptible to rust
- 3 Illustrations of typical rust points
- 4 General idea
- 5 The perfect rust protection method
- 6 The ordinary rust protection method
- 7 Cleaning and washing
- 8 Importance of existing rust removal and bare metal surface etching
- 9 Timing and weather protection
- 10 General procedure of underbody rust proofing
- 11 Choice of coating types
- 12 Popular application combinations
- 13 Final notes
- 14 Unsorted quick tips
- 15 Additional reading
- Generally speaking, Suzuki vehicles have relatively poor rustproofing from the factory, in line with their relatively low price when new.
Areas of all Jimny generations which are most susceptible to rust (from most common to less common):
- Body / cabin and suspension carriers (mounting points) on the chassis;
- Easy to see from underneath after a good wash, unless the underbody had been "protected" (mucked) with bitumen / tar or some other gunk;
- On Jimnys 3, body just behind front driving lamps;
- Visible only after removing front wheel arch liners (relatively simple) or removing the head lamps (not so simple);
- Various factory welding points on the chassis and on the axles as well;
- Body behind the rear bumper (and below rear vertical lamps for Jimnys 3);
- Visible only after removal of the rear bumper (relatively simple);
- Boot / trunk floor;
- Easy to check by emptying the boot.
- Body floor below the rear seats (and especially where it meets the rear inner wheel arches);
- Visible only after removing the rear seats (quite simple);
- Rust usually starts around the threaded holes in the floor for the bolts which secure the rear seats and rear seat belts anchors to the vehicle, and also at the connection points between the floor and rear inner wheel arches.
- Sills below the side doors (and behind plastic sill covers for Jimnys 3);
- On Jimnys 3, inner side visible from underneath the car. Outer side visible only after removing large plastic sill covers (risky);
- Behind side plastic mouldings (claddings), especially around rear wheel arches;
- Visible only after removing the mouldings (risky).
- Floor between front seats and the engine compartment;
- Usually where left front passenger's left foot is located and where right front passenger's right foot is located.
- Inner wheel arches;
- Usually rear wheel arches, in combination with rusty floor below the rear seats;
Body carriers on the chassis
Area behind the head lamps
- Salvage efforts on a thoroughly rotten rear floor section
General idea
- Bitumen or tar based (the oldest and cheapest type);
- Waxes;
- Polyurethanes;
- Lanolin (sheep wool wax) based;
Separating body and the frame
- The only two effective methods to remove elastic compounds is to either heat them up and manually scrape them off (messy) or to extremely cool them down (with "dry ice") and then chisel them off while they are brittle.
- For example: automotive wax, bitumen-alike coating, plastic-alike coating (not recommended for outdoor applications), lanolin, polyurethane ("bed-liner") coating, etc.
General description
"Enhancing" the method
Importance
- Unless the vehicle is bran' spankin' new from the factory, its underbody has more layers and varieties of dirt and filth stacked onto it than there are galaxies in the universe.
- This is valid even if you wash it regularly.
- Removing all the contaminants from the surface to be overcoated is of paramount importance, as the long term adhesion of the coating to be applied critically depends on the cleanliness and roughness of the underlying surface.
Washing agents
- Most detergents and degreasers do not have the capability to thoroughly clean the surface of the underbody, due to a phenomenon of composite "fused" dirt called "traffic film".
- Although regular power washing with a common degreaser removes all mud, dirt, sand and common filth from the underbody and makes it appear clean, the final layer of traffic film stays on firmly on the surface.
- The only way to convince someone that traffic film is still present on an apparently clean surface is to let them see the same surface again (in a very different color) after the traffic film has been removed from it.
- Traffic film is so tough to remove than the only adequate chemicals for its removal are specialized detergents and degreasers, which explicitly state that they remove traffic film (hence called TFR - "traffic film remover").
- Many people have tried hard with various "non-TFR" detergents and degreasers, and the success is minor at best even with extreme effort and persistence.
- Even with a TFR, you might have to power wash the vehicle several times in order to completely remove traffic film.
- Only after traffic film is removed from the underbody, you will really see how it used to look like when the vehicle left the factory.
- TFRs are rather strong chemicals which can damage paint if used in high concentrations.
- Therefore, beware what you wash with which concentration of TFR, and make certain that you rinse it of thoroughly.
- Note that the "strength" and/or quality of TFRs vary between manufacturers or even among their products.
- For washing the underbody, it would be the best to use a stronger variant of TFR (or a relatively high concentration of it if allows for several dilution ratios).
- Power washing with hot water is significantly more effective than with cold water, but requires relatively expensive power washing machines and willingness to spend plenty of energy.
- Some detergents or TFRs do not like hot water.
Proper washing procedure
- Check the underbody first for any thick / heavy sediments of baked mud, stuck or glued grass or branches, etc.
- Remove those heavy deposits manually to enable better penetration of the liquids to the underbody itself during power washing later.
- Remove the drain plugs from all the cavities.
- Wash the cavities with a general purpose automotive detergent / degreaser and then rinse them off thoroughly.
- Repeat this step at least twice.
- Temporarily reinstall the cavity drain plugs.
- This will prevent most of the detergent from entering the cavities during underbody washing.
- Power wash the underbody first with a general purpose automotive detergent / degreaser in order to remove the main / common mud, dirt and filth.
- This will decrease the consumption of a TFR later on (which is more expensive), and allow better penetration of TFR directly onto the exposed traffic film layer.
- Rinse the underbody with clear water.
- Soak the underbody with a TFR.
- Thoroughly rinse the underbody again.
- Since the underbody probably will not be 100% clean after the first pass of TFR, repeat the previous two steps one more time.
- Remove the cavity drain plugs again.
- Finally, you must allow or force the washed surfaces to dry off completely before you coat them.
- Hidden, indented or concealed surfaces can take much more time to dry.
Washing the cavities
- Treating the cavities in the chassis and in the body is even more important than treating the exposed areas of the underbody.
- This involves (power) washing the cavities prior to spraying them with a cavity wax.
- It is best to wash the cavities before washing the underbody.
- This way, the muck that drains from the cavities will not contaminate the freshly cleaned underbody.
- Cavities will also have more time to dry while you are busy washing the underbody.
- Don't forget to remove all drain plugs from the cavities before washing them.
- It is recommended to manually brush the cavities which have relatively large access holes prior to washing them, in order to partially scrape off and release the accumulated and hardened dirt and dust inside of them.
- This will significantly improve washing efficiency, since it is near impossible to effectively power wash the cavities, because a water jet can rarely be directed at their surfaces perpendicularly.
- It is best to use long cylindrical brushes, like the ones designed to clean ventilation pipes or even chimneys.
- Such brushes should be available in any home improvement store, or even in generic supermarkets.
- Beware when using very abrasive brushes (usually the ones with metal wires or metal nets, intended for cleaning chimneys), as they will damage paint inside the cavities.
- However, if the cavity is already rusty (usually the case with the chassis rails), than this kind of brush is actually a good tool to remove some of that rust.
On Jimnys 3 at least, the cavities with access holes large enough for long cylindrical brushes are:
- Chassis rails and tubes;
- These usually have the most amount of the most stubborn dirt inside of them by far compared to all the other cavities;
- Read more in the rest of this article on how to remove rust from the insides of a rusty chassis.
- Below / behind rear vertical lamps;
- Accessible when rear seat belts are removed;
- Side door sills;
- Accessible through holes which house the rear speakers;
- The most important cavities to wash are the interiors of the chassis rails and tubes.
- This includes both longitudinal rails and all transverse tubes.
- They should be washed and rinsed multiple times, while pushing the washing hose through them all the way front and back multiple times and by twisting and tossing the hose around inside of them while doing so.
- Some power washing machines have an option of attaching special nozzles / heads (usually from the same manufacturer), which are designed to be inserted into cavities and manipulated inside (rotated and moved around) while the washer is operating.
- Even if such accessories are not available, the high pressure water output hose from the power washing machine can be inserted into most cavities without any head attached to it, and then manipulated (tossed around) while it is inside and the machine is running.
- Using TFR to wash the cavities is generally not needed (except perhaps for the chassis), as the usual contaminants which form traffic film hardly get inside of them.
- Therefore, a standard automotive detergent / degreaser should suffice.
- Rinse the cavities with plenty of clear water, in order to insure that no degreaser or detergent remains inside.
- Allow for an extended amount of time for the washed cavities to dry - at least several days is preferred.
- It takes much more time for them to dry than for surfaces exposed to the outside world, even during a hot summer day.
- This discrepancy is even much more pronounced during colder weather.
Methods to reduce the time needed to dry the cavities:
- Blow the cavities with plenty of compressed air.
- It is preferred to use an oil-less air compressor or oil-lubricated air compressor with an oil filter in the output line, so that the compressed air does not contain oil droplets, which will contaminate the surfaces which are being dried.
- Use a hot air gun or an ordinary hair dryer.
- Take care not to blow hot air onto a single point for an extended period of time, or it might overheat the paint on that spot.
- This method is difficult to apply to cavities which have small access holes.
- Use a leaf blower.
- These machines are particularly useful for long cavities like the chassis rails.
- It is also a good idea to blow through a chassis rail with a leaf blower after brushing or scraping the dirt inside of it and prior to washing it.
- Rust is like cancer.
- Equally as important as thoroughly removing all the rust from a surface is thoroughly roughening / keying / etching the healthy underlying surface to enable strong and long lasting adhesion of the first (direct to metal) paint coating.
- A standard method of rust removal is by using manual or powered wire brushes (attached to drills, grinders, etc.) or sand paper.
- Much more thorough rust removal can be accomplished only with sand blasting.
- Typical case where sand blasting excels over wire brushing is elimination of rust from pits, grooves etc (heavy pitted rust).
- Removing specks of rust from pits is quite difficult otherwise.
- Very rough and completely clean surface finish is required for proper adhesion of any primer paint coating over bare metal.
- The additional (extremely important) effect of sand blasting is that it also inherently thoroughly keys / etches / scars the underlying healthy surface (onto which the paint will be applied).
- If the rust is removed using wire brushes, the clean underlying surface then has to be additionally roughened / keyed / etched for proper primer paint coat adhesion, because wire brushing does not leave nearly rough enough surface (it even tends to polish it).
- Polished surface is quite the contrary to what any paint coating needs for proper strong adhesion.
- Roughening of the surface after wire brushing is usually done with 150-250 grit sand paper (two passes - second pass perpendicular to the first pass).
- This is the minimum surface roughening level required for any hope of long lasting proper paint adhesion, but a proper sand blasting will always create a profoundly rougher surface.
- If tiny specks of rust still remain after the rust removal (usually in the pits after wire brushing), the treated surfaces should then be "painted" over or sprayed over with some chemical which dissolves rust.
- Its job is to dissolve the last tiny thin remains of rust which have stayed in some pores or scratches after the mechanical removal has been performed.
- A rust treatment chemical usually needs some time (counted in minutes or even hours) to do its job.
- Popular chemicals for this purpose are phosphoric acid and hydrochloric acid.
- Inform yourself of characteristics and hazards of any acid which you intend to use, especially hydrochloric acid!
- Hydrochloric acid makes a quick genocide of the rust.
- However, it also eats away good metal too, and its vapors can corrode surrounding metal as well as your eyes and lungs if used indoors.
- If that does not scare you enough, know that it may also cause your penis to fall off.
- One positive side effect of its metal eating capability is that it will also etch / roughen the metal which it eats, making the surface more suitable for the future primer coating.
- Hydrochloric acid should not be used on any metal which has a structural bearing role (for example: chassis, tow bar, suspension arms, etc.), as it causes a fatigue in the metal due to the effect called "hydrogen embrittlement".
- Some rust elimination chemicals require rinsing them off with a suitable liquid after a certain amount of time, or even grinding them off after they harden off, while others allow further coating applications.
- Even with those chemicals which allow subsequent overcoating, it is much better to remove them from the metal (after they had done their job) and then coat directly on top of bare metal.
- Reason: It is always better to apply a primer directly onto bare metal instead onto some intermediate coating of inferior adhesion properties.
- In other words - no rust elimination chemical can be a good coating layer!
- Note that most of these rust elimination chemicals do not seal the surface against future rusting!
- The process of roughening the surface with sand papers after wire brushing should be performed after the rust elimination chemical has done its work and after it has been rinsed off and the surface has dried.
- This way, the sanding will also remove any remaining dried parts of the rust elimination chemical.
- A common misconception is that the best chemicals for eliminating rust are the so called "rust converters" - the ones which chemically alter (transform) the rust into another non-ferrous material (making it impotent).
- One of the reasons for the misconception is that such chemicals are usually much more expensive than ordinary "rust melting / elimination" chemicals, so people go by the logic "what's expensive is supposed to be effective".
- Use of magical "rust converting" chemicals should be strongly avoided.
- They are usually some form of tannic acid.
- To make the elaboration simple, two main reasons against tannic acid are:
- It rarely penetrates the rust more than its shallow surface, thus leaving its inner layers untouched.
- Don't believe this?
- Then apply this kind of chemical to a rusty surface and wait for it to finish its job as specified by the manufacturer of the chemical.
- The color of rust will probably change from brown/orange to black or dark blue or similar.
- Then scratch the surface with a sharp knife or a sharp nail.
- The scratch will most probably reveal the good old brown/orange rust below the converted top layer.
- The converted top layer of rust prevents the corrosion inhibitors, which are usually a part of a subsequent coating like a wax or a paint primer, from performing their job.
- Reason: The converted layer behaves like a barrier between the corrosion inhibitors and the inner layer or rust under it, enabling the rust to still thrive under.
- For example, if you sand blast a metal surface, and then load it onto a trailer to be taken somewhere else for the painting, if it's a cloudy day with high humidity (let alone rainy day!), the metal will quickly develop rust flecks ("flash rust") on the way to the next station.
- The rougher a bare metal surface, the more susceptible to flash rusting it is (that's the nature of things).
- It is also important to obey manufacturer's curing times and environmental application temperatures for each used chemical product.
- It is for this reason important to carefully observe and plan when buying various chemical products, because some products' overly quick or overly slow curing times or restrictive temperature range can complicate your working schedule and timing.
- An important exceptions to this are epoxy primer paints.
- That is one of the reasons why epoxy primer paints are the preferred type of primer coating for high quality rust proofing treatments.
- If a primer coating is porous, you need to apply final coating(s) of your choice (which need to be airtight) as soon as the primer paint dries off.
- A lot of people leave the project for a while (maybe to take a rest or a vacation) after the application of a primer paint, thinking that they have covered the bare metal and how the main "rust shield" is on, but it probably isn't!
- Thoroughly wash and rinse the underbody multiple times, first with a standard automotive detergent and then with a traffic film remover chemical.
- Sand blasting is by far the best / most thorough method for multiple reasons, but is dirty and expensive.
- If there are any localized specks of rust still remaining which can not be eliminated mechanically, you need to eliminate them chemically.
- Use rust elminating acids, like phosphoric acid or even hydrochloric acid.
- Using sand paper in multiple directions, abrade / roughen up any non-sandblasted bare metal surface or painted metal surface which you intend to overcoat.
- Reason: any new coating adheres much better on a rough surface than on a smooth surface.
- This step is especially important in case of bare metal surfaces which had been wire brushed, as wire brushing tends to polish them.
- Clean and degrease the all parts of the underbody which had been exposed to dust or other contaminants during the previous activities and let dry completely.
- Apply one coat of primer paint on all bare metal surfaces.
- This includes any bare metal welds or bare metal panel joins.
- See more info below on best primer types.
- Apply seam sealant to all previously rust-treated areas which have welds or where two metal parts/panels join together.
- It is best to use a polyurethane seam sealant - the more expensive, the better.
- The welds and panel joins should have one layer of cured primer coating over them prior to the application of the seam sealant.
- Now apply the 2nd coat of the same primer paint over all surfaces which had been coated two steps before.
- This includes painting over the cured seam sealant.
- Apply a stonechip coating of your choice (bitumen-based, synthetic rubber based, polyurethane, etc.) to the entire underbody.
- Apply underbody wax over the stonechip coating.
- Apply cavity wax in all cavities (inside the chassis rails, inside door sills, inside doors, inside anything that is hollow.
- Take a vacation.
General overview
- There is no single coating type which is equally suitable for the entire underbody.
- For example, a coating for inside the cavities like inside the doors has to be different than the coating on the wheel arches.
- Therefore, multiple coating types need to be used on different parts of the underbody.
- There are numerous schools of thought / beliefs on which type of coating is best for anti stone chip protection in the exposed areas of the underbody.
Primer paint
In case that there is bare metal to protect, a primer paint is necessary no matter what subsequent / final coating is to be applied.
The best primer paints are the ones which contain all of the following properties (from most to less important):
- Epoxy;
- "High build";
- 2-component ("2K");
- Anticorrosive;
The main advantages of epoxy over other types of materials are:
- Exceptional toughness (resistance to impacts and abrasion);
- Very good resistance to temperature, chemicals and mechanical stress;
- Non-porous;
- Does not allow water or moisture through.
- This is especially important when leaving a primer painted metal surface overnight (or for multiple days) before applying further coatings to it.
- This is usually the case in practice.
- All these properties enable most epoxy primer paints to also serve as final / top coat paints (officially endorsed by their manufacturers) as long as they are not exposed to UV rays from the Sun.
The disadvantages of epoxy paints:
- Usually quite toxic to work with;
- Very difficult to remove after they cure;
- Relatively expensive;
- Do not like exposure to the Sun (UV rays);
- Irrelevant for the underbody applications.
About the "high build" property:
- "High build" means that the paint is designed to have a relatively high dry film thickness.
- In other words: designed to be applied in a rather thick layer.
- High thickness further increases coating's flexibility and toughness.
- "Dry film thickness" refers to the thickness of the applied coating after it cures.
- Generally, every coating is designed for a certain range of DFT.
- It is equally bad to apply it thinner than the designed DFT range as it is to apply it thicker than the designed DFT range.
- When the applied DFT is too high, it usually causes the coating to crack later on.
- For example, the optimal DFT of common "regular" epoxy primers is around 20 to 80 micrometers, while the optimal DFT of common "high build" epoxy primers is anywhere from 150 to 500 micrometers or more!
- Another advantage of many "high build" primer paints is that many of them are designed to be applied by brush or roller, which is not the case with "regular" primers (as those two methods always achieve high DFT).
About 2K:
- "2K" usually means that the paint comes in two components / parts - the base and the hardener - and the two must be mixed together in a certain ratio before the application.
- The general rule is that a 2K paint will always have better chemical and physical properties (longevity, etc.) than a 1K paint.
About anti-corrosive properties:
- Anti-corrosive primers are those which contain rust inhibiting chemicals.
- Such chemicals interact with any remaining rust on the bare metal surface and slow down its progress.
- It is always better to have zero rust on the bare metal surface to be coated, in which case no rust inhibitors are needed.
- However, if that can not be achieved, than rust inhibitors in the primer coating are the 2nd best weapon to have.
Product examples:
- An example of a popular and long time proven high build 2K epoxy primer paint is Jotun Jotamastic 87.
- An industrial coating used for coating bridges, off-shore oil refineries, liquid tanks, girders, etc.
- Quite popular among enthusiast restorers of old timer vehicles.
- Can be applied by roller or by brush, as well as by a high pressure airless spray gun.
Bitumen / tar
- Bitumen / tar based products are the oldest and still the most popular type of general purpose underbody rust protection (predating automobiles).
- They are sometimes called "rubberized coating" (especially in USA), but this classification is not synonymous, as there are synthetic rubber coatings and vinyl coatings which could also be classified as "rubberized".
Advantages:
- Very cheap;
- Simple to apply;
- Have exceptionally high dry film thickness;
- They are therefore quite elastic and even provide certain sound and heat insulation;
- Their elasticity and thickness combined give them exceptional resistance to abrasion and chipping when rock impacts or scraping occurs.
- Can usually also be applied by brush (not just by a forced air gun).
- Impossible to wash off with power washing.
- Excellent choice of underbody coating when attempting to hide existing rust and damage prior to selling the car and presenting the car as "protected from rust" to naive customers.
Disadvantages:
- Do not tolerate heat, so should be avoided in the engine compartment, near the exhaust pipes, etc.
- Such coatings tend to lose their elasticity over time (sooner or later), when they become brittle and develop cracks or (more commonly) start to delaminate from the surface.
- Since they are usually very thick, local cracks and delaminations are usually very hard or even impossible to spot, thus staying undetected for a long time.
- When they crack or delaminate, they trap moisture and salts between them and the surface which they are supposed to protect, rapidly accelerating its demise.
- A metal "protected" by bitumen can rust several times faster than if it had been left bare and exposed to the outside environment!
- Bitumen and tar tend to delaminate more if the underlying surface onto which they had been applied has not been cleaned properly of dust, grease or previous rust and then properly roughened.
- It is impossible to detect a deteriorating / rusting metal surface behind such coatings due to their thickness and elasticity, until most of the metal behind the bitumen gets so rotten that the entire metal panel collapses.
- If applied clumsily or without proper protection of areas which should not be coated (bolts, springs, bushes, pipes, hoses, moving parts like the drive shafts, etc.), they will "gunk up" the underbody and make any future servicing job a very miserable one.
- Many mechanics refuse to service the drive train and the suspension of such vehicles.
- Nobody should blame them for such policy.
- They are extremely difficult to remove, with lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots of tedious manual labor required.
- Sand blasting is usually completely ineffective, as bitumen and tar are exceptionally resistant to abrasion.
- Also completely ineffective are any wire brushes and sand papers, as the bitumen rapidly clogs them up.
- Chemical removal methods do work, but they require a lot of liquid and kilometers of rags to wipe the melting gunk off.
- In the end, the most effective method is a chisel and a hammer during as cold day as possible (to have the bitumen as brittle as possible), with inevitable damage to the metal due to chiseling.
- Pro tip: It is best to delegate the bitumen removal job to convicts, prisoners of war or feminists.
- An example video from USA says more than a thousand pictures, each of which says more than a thousand words.
- The video portrays the fate of a 4WD vehicle which had been "protected" by a bitumenous rust proofing coating product called "Ziebart", which is quite popular in certain parts of USA.
- That coating had been applied to that vehicle when the vehicle was new.
- The author stated that the vehicle was less than 10 years old when the video was made, but they did not state its exact age (guessing somewhere between 5 and 8 years old).
Conclusion:
- Strongly avoid using bitumen or tar based underbody coatings, due to high risk of accelerated failure and the extreme difficulty of removing the coating.
- While the applied bitumen / tar coating typically looks pristine for years and years after the initial application, the protected Cinderella's carriage might suddenly turn to a pumpkin after the invisible rusty deadline rings!
- The only parts of the underbody where a bitumen based coating might make sense is the wheel arches, which are the most stone-chip exposed areas of the underbody by far, and also create the most noise when driving on gravel or through mud.
- But even for this application it is better to use something more expensive.
Wax
- There are several types of wax-based materials which are suitable as underbody protection coatings.
- They are usually differentiated by their viscosity, temperature resistance and additive packs.
- This usually classifies waxes into three groups based on intended usage:
- Cavity wax;
- Used in cavities, holes and crevices.
- They usually have low viscosity, low resistance to abrasion and chemicals and low temperature resistance.
- These "disadvantages" provide them with very good flow and "creep" properties (they seep and flow into pores, seams, cracks and other tight spaces and embed themselves to seal them).
- High temperature resistant wax;
- Used in the hot engine compartment, or on the underbody and in wheel arches.
- Underbody wax;
- Usually have higher resistance to chemicals (salt, urine, crap, acidic mud, etc.) and somewhat higher dry film thickness and some self-sealing / self-healing properties (if scratched or chipped, the coating re-seals the gap on itself).
- Cavity wax;
- There are also some "hybrid" products which are a mix of wax and bitumen, or wax and oil, etc.
- Such products are an attempt to combine the best of two worlds.
- Example 1: Car System KS-800
- Example 2: Hammerite Waxoyl
Advantages:
- Very good creep-in and sealing properties inside cavities, crevices and holes.
- Usually somewhat transparent, enabling to see what is underneath them.
- Usually have some self-sealing ability when lightly damaged (scratched) by rock impacts or minor scuffs.
- Relatively easy to remove by applying degreasing products.
- Dielectric, so safe to use on wiring and electrics.
Disadvantages:
- Usually have to be applied by a forced air gun or from a compressed air spray bottle ("rattle can");
- Can be a bit toxic to the operator during application (not after they dry);
- Can be relatively expensive depending on the product;
- Wash off and scrape off relatively easily, requiring regular check-ups and re-application on such areas;
- Product quality can vary highly depending on the manufacturer;
Conclusion:
- Waxes are an excellent choice for application inside cavities like inside the doors, sills and chassis.
- Relatively poor abrasion and washing off resistance is the main disadvantage of waxes when applied to the underbody, especially for all-terrain driving, where direct contact of the underbody with mud, snow, grass, branches or rocks is expected, as well as regular thorough power washing of the underbody.
- Regarding the underbody, a wax might be the optimal choice only for the parts of the underbody which are somewhat obscured from direct contact with the ground (deep mud, deep snow, etc.), like above the fuel tank, above the gear box, etc.
- A high temperature resistant wax is a great choice for the engine compartment, unless the car is going to wade through deep muddy water or through mud holes.
Lanolin
- Lanolin, also called wool wax, is a natural product from sheep.
- It has a very long history of wide array of uses, one of which is protection against rust.
- Lanolin-based vehicle underbody rust protection products are yet another compelling choice.
Advantages:
- Hermetically seals the surface.
- Relatively good wash-off resistance when power washing is applied.
- Some lanolin-based anti seize grease is alleged to last 10 years on bolts in sea water.
- Usually ecological and harmless to health during application.
- Note: While lanolin itself is completely harmless and even eatable ("food grade safe"), any additives in a lanolin-based product might not be!
- Relatively easy to apply - brush on or spray bottle or compressor.
- Easy to clean off if it gets where it should not be, including hair and eyes.
- Should dry to a semi-hard waxy resin (product dependent).
Disadvantages:
- Most lanolin-based products smell like ... sheep.
- Abrasion resistance insufficient for hard-impact areas, like inside wheel arches.
Conclusion:
- With a proven several thousand year old history of use as (salt) water repellent and a few decades of history as a vehicle underbody rust protection product, lanolin is a compelling choice.
- Just like there are different types of wax based products for different areas of the vehicle, so are different lanolin-based products.
- Lanolin could be viewed just as another type of wax, which would even be roughly correct, so similar conclusions for the waxes are valid for the lanolin as well.
Oil
To be written...
Synthetic resins
To be written...
Polyurethane
To be written...
Typical examples of such coatings are U-pol Gravitex and U-pol Raptor.
Many people who restore old timer vehicles take the following procedure:
- Wash the underbody and the cavities.
- Completely dismantle the vehicle.
- Cut out any rotten parts of the cabin and the chassis and patch weld them.
- Sand blast the chassis (if it exists), the entire cabin and most suspension parts.
- Spray the the entire cabin (except its underside) with 2K "normal build" epoxy primer in two coats (with the application of a polyurethane seam sealant in between to most panel joints and all welds).
- Spray the entire cabin (except its underside) by a top coat.
- Spray or brush the underside of the cabin with a 2K "high build" epoxy primer in two coats (with the application of a polyurethane seam sealant in between to most panel joints and all welds).
- Spray or brush the underside of the cabin with an underbody wax.
- Spray the cavities in the cabin with a cavity wax.
- Some people take the sand blasted chassis, suspension arms, axles and other "thick metal" to be hot dip zinc plated.
- After zinc plating, they spray or brush zinc plated parts with underbody wax, including cavity wax for the insides of the chassis.
- If no zinc plating has been performed:
- They spray or brush the chassis and suspension parts with two layers of 2K "high build" epoxy primer paint (with the application of a polyurethane seam sealant in between to all welds).
- They spray them with underbody wax, including cavity wax for the insides of the chassis.
- The described method provides more than enough decades-long underbody rust protection for on-road old timer vehicles.
- Either the zinc plating or the epoxy paint will easily withstand all usage scenarios through which such vehicles will go through during the next decades to come, especially with wax on top of them.
- However, these layers of protection are not enough for all-terrain vehicles which are used in all-terrain duty.
- An additional anti-stone chip layer is required between the epoxy paint and the wax on all sections of the underbody and suspension parts which have relatively high risk of abrasion.
Final notes
- Be prepared to pay / "tip" them more for a thorough job execution though!
Unsorted quick tips
This chapter contains some new quick tips which were added in a haste and thus there was no time to properly incorporate them into the chapter(s).
- Read more here.
- This guide contains some very useful and practical info on DIY application of 2K high build epoxy primers.
Additional reading
Page last edited on 4/09/2020 by user Bosanek
