- Clicking when in 4WD when turning;
- Banging and snatching of the steering wheel;
- Loss of 4WD transmission to a front wheel;
CV joint information
Identifying type
Suzuki uses three different CV joint types in the Jimny:
- The first type is straight forward to purchase on the parts aftermarket, with offerings from several manufacturers.
- The second type is very hard to find on the parts aftermarket, with only one or two products.
- Not much is known about the third type, except that is was used by some (but not all) petrol Jimnys built by Santana in Spain.
Type 1 | Type 2 | Type 3 | |
Left side set | 44102-81A00 | 44102-84A00 | 44102-82A00 |
Right side set | 44101-81A00 | 44101-84A00 | 44101-82A00 |
CV joint | Model used by Suzuki | Balls | Inner splines | Outer splines | Outer case diameter | Inner case diameter | Shaft diameter |
Type 1 | NTN BJ75LAC | 6 | 19 | 26 | 91.6 mm | 72.6 mm | 19.0 mm |
Type 2 | NTN EBJ82 | 8 | 29 | 26 | 91.6 mm | 72.6 mm | 21.2 mm |
Type 3 | AYD 143 Y3 164 | 6 | 20 | 26 | ? | 72.6 mm | 24.5 mm |
CV joint type numbers (like type 1, 2 and 3) are not official Suzuki numbers. It's just a "BigJimny" nomenclature for easier reference.
Additional notes:
- CV joint "NTN BJ75LAC" is also sometimes marked as "NTN 75LAC CT9U".
- While NTN EBJ82 (which Suzuki originally sources and sells as their own) has 8 balls, it appears that all aftermarket replacements have 6 balls.
- This is not a critical mismatch - the replacements will fit just fine.
- Only the longevity is questionable (like with any aftermarket part).
- Good luck finding any of these NTN CV joints anywhere on the aftermarket!
- You will probably have to buy aftermarket CV joints from some other manufacturers.
- If anyone knows anything about "type" 3 CV joints which are specific to some Santana Jimnys, please contribute to the table above!
- There are some indications that type 3 CV joint might be compatible with type 1, but someone needs to verify that on a Santana Jimny in practice.
CV joint vs. vehicle compatibility
Notes about the table below:
- No guarantees are made about the accuracy of the data in the table.
- In other words, your vehicle may be an exception from the classifications which are presented in the table.
- Check the specific CV joint type for your vehicle before ordering!
- The most reliable method is by checking the OEM P.N. of a "CV joint + halfshaft" set with a local Suzuki dealer, based on your vehicle's VIN.
Engine | Country of manufacture |
VIN code (first 9 characters) |
VIN code (last 8 characters) |
CV joint type |
G13BB | Japan | JSAFJB33V | ANY | Type 1 |
G13BB | Spain | VSEFJB33V | ANY | Type 3 |
M13A | Japan | JSAFJB43V | up to 00186627 up to 40160140 |
Type 1 |
M13A | Japan | JSAFJB43V | from 00186628 from 40160141 |
Type 2 |
M13A | Spain | VSEFJB43V | ?ANY? | Type 3 |
K9K 700 K9K 266 |
Japan | ЈSAFJB53V | ANY | Type 2 |
K9K 700 K9K 266 |
Spain | VSEFJB53V | ANY | Type 2 |
Pictures of Type 1 CV joints
- Here is the genuine NTN 75LAC CV joint which Suzuki sells
Pictures of Type 2 CV joints
- Above is the genuine NTN EBJ82 CV joint which Suzuki sells only in a super-duper-expensive set together with either a left or a right halfshaft.
- This one was removed from a type 6 Jimny after it fell apart.
- Therefore, there are no pictures of its internals as all the balls and internal pieces fell out during removal of the CV joint.
- However we counted 8 balls which fell out of it on the floor!
- This is a compatible 6-ball copy (probably Herth+Buss Jakoparts model J2828040, but Martin needs to verify this)
- This is another compatible 6-ball copy, NKN model N-5979-2HO
Pictures of Type 3 CV joints
Add more if you have them!
Prerequisites
Required parts
The table
Part name | Quantity | Suzuki P.N. | Aftermarket replacements | Comments |
Constant velocity joint |
1 piece | Type 1:
Type 2:
Type 1:
Type 2: |
Halfshaft oil seal |
Steering knuckle swivel seal |
Differential oil |
1.1 - 1.65 litre |
Heavy duty grease(s) |
A handful or so |
Gasketing sealant |
A small tube |
A calendar with pictures of (half)naked women |
12 pictures / months |
- The following CV joint types (see the dedicated chapter about CV joints above for more info):
- A proper halfshaft oil seal;
- The large swivel/knuckle seal;
Notes about greases
- This heavy duty lithium grease is the grease of choice on BigJimny shop.
- This is just a presumption, because it is very thick and very "gooey" - but it might actually be great in practice.
- Somebody has yet to try this grease in a CV joint and in a wheel bearing and report the long-term effects.
Required tools
![Spanner Icon.png](/mediawiki/images/thumb/a/a0/Spanner_Icon.png/50px-Spanner_Icon.png)
- Assorted screwdrivers
- Circlip pliers (external)
- A ball joint splitter
- 1" imperial Socket
The Video
Removing the Caliper and pads
Removing the Brake Disc
Dismantling the Hub
Re-assembly
- You may wish to change the king pin bearings and oil seals at this point if you wish.
Page last edited on 2/12/2019 by user Bosanek
