CV joint replacement
Ooo printeradmin.pngPrint this page as a PDF
Changing the CV joint
  • Clicking when in 4WD when turning
  • Banging and snatching of the steering wheel
  • Loss of 4wd
CV joint information
Suzuki uses two different CV joints in the Jimny. One is straight forward to purchase on the parts market and the other is nearly impossible to source.
  • Type 1: 6 balls, 26 external splines and 19 internal splines. - Easy to source (one I have is marked NTN 75LAC CT9U)
  • Type 2: 8 balls, 26 external splines and 29 internal splines. - Difficult to source, 6 Ball Jakoparts J2828040 is supposed to fit. (possibly marked NTN EBJ82)
Note: I can get Type 1 for you, I just do not stock it as too many people bought the wrong one and wanted to return it.
Model Balls Inner Splines Outer Splines Outer Case Dia Inner Case Dia Shaft Dia
NTN BJ75LAC 6 19 26 91.6mm 72.6mm 19.0mm
NTN EBJ82 8 29 26 91.6mm 72.6mm 21.2mm
NTN 75LAC CV Joint
NTN 75LAC CV Joint - 26 Outer splines
NTN 75LAC CV Joint - 19 inner splines
  • Assorted screwdrivers
  • Circlip pliers (External)
  • A ball joint splitter
  • 1" Imperial Socket
The Video
Removing the Caliper and pads
Jimny Front Caliper
Unbolting the caliper
Open brake caliper
Removing the brake pads
Removing the Brake Disc
Carrier bolt
Caliper tied to Spring
Disc removal using bolt
Dismantling the Hub
Torx bolt on hub
Removing the circlip
removing a vacuum pipe
Removing the swivel seal bolts
Splitting the ball joint
undoing the Kingpin bolts
The KingPins are also held in with sticky sealant so you will need to prise them out. The hub will now pull off and the driveshaft can be removed. Depending on how broken the CV is the shaft may come out in two pieces.
The next stage is to CLEAN, CLEAN and then CLEAN again. Clean the swivels inside and out, clean the knuckles and make sure all broken CV parts are removed.
Removing the C-Clip
The CV Joint is held on the driveshaft by a hidden C-Clip. The only way to dismantle a whole CV Joint (yours may already be in bits if you have really broken it!) is to drive the joint off with a hammer. Clamp the driveshaft into a vice and, holding the joint VERY straight, hit the cup with a hammer and drive it off.
New CV Joint
Now put the new C-clip onto the shaft and tap the new joint into place.
Re-assembly
This is basically the reverse process. You may wish to change the kingpin bearings and oil seals at this point if you wish.
The greased CV joint
Applying sealant
Page last edited on 6/08/2016 by user Mlines
