Transmission gearing ratios
Revision as of 12:39, 16 January 2018 by Mlines (talk | contribs)
Gearbox, Differential and Transfer Box Ratio Information
Date Country Engine Gearbox Gear 1 Gear 2 Gear 3 Gear 4 Gear 5 Transfer Box High Low Final Drive
1998 UK/EU G13B Manual 3.652 1.947 1.423 1.000 0.864 Manual 1.320 2.145 3.909
1998 UK/EU G13B Auto 2.962 1.515 1.000 0.738 N/A Manual 1.320 2.145 4.090
2001 UK/EU M13A Manual
3.652?
1.947?
1.423?
1.00
0.864?
Manual 1.32 2.145 3.909
2001 UK/EU M13A Auto
2.962?
1.515?
1.000?
0.738?
N/A Manual 1.32 2.145 4.090
2005+ UK/EU M13AVVT Manual 4.425 2.304 1.674 1.190 1.000 Electric 1.00 2.002 4.300
2005+ UK/EU M13AVVT Auto 2.875 1.568 1.000 0.695 N/A Electric 1.32 2.643 4.090
2005+ EU K9K Manual 4.246 2.357 1.695 1.242 1.00 Electric 1.00 2.002 3.416
2000 JP K6A Manual 4.031 2.391 1.513 1.00 0.790 Manual 1.320 2.145 5.375
2000 JP K6A Auto 2.902 1.515 1.00 0.736 N/A Manual 1.320 2.145 5.375
2010 JP K6A Manual 5.106 3.107 1.908 1.254 1.000 Manual 1.320 2.643 4.300
2010 JP K6A Auto 2.875 1.568 1.000 0.696 N/A Electric 1.320 2.643 5.375
See below for some worked examples test:
2005 VVT manual gearbox Jimny, engine at 4000 RPM and in 5th gear High Ratio
Gearbox input = 4000 RPM
Gearbox ratio = 1
Gearbox output = 4000 RPM
Transfer box input =4000 RPM
Transfer box ratio = 1
Transfer box output = 4000 RPM
Diff input = 4000 RPM
Diff ratio (final drive) = 4.3
Diff output = 465 RPM
Wheel input = 465 RPM
Wheel diameter = 28 inches
Road speed = 77.7 miles per hour
2005 VVT manual gearbox Jimny, engine at 3000 RPM and in 1st gear Low Ratio
Gearbox input = 3000 RPM
Gearbox ratio = 4.425
Gearbox output = 678 RPM
Transfer box input =678 RPM
Transfer box ratio = 2.002
Transfer box output = 338.6 RPM
Diff input = 338.6 RPM
Diff ratio (final drive) = 4.300
Diff output = 78.5 RPM
Wheel input = 78.5 RPM
Road speed = 1.5 miles per hour
Note: For the road speed calc you can use your maths from school or a web calculator - www.4qd.co.uk/road-speed-calculator/----
Page last edited on 16/01/2018 by user Mlines
