King pin bearing change
Revision as of 18:45, 13 May 2016 by Leftcase (talk | contribs)
Changing the Kingpin Bearings
  • Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Leaking front swivel
Note Icon.pngClick on images to make them larger
Changing the bearings
  • Assorted screwdrivers
  • Circlip pliers (External)
  • A ball joint splitter
  • 1" Imperial Socket
The Video
Removing the Caliper and pads
Jimny Front Caliper
Unbolting the caliper
Open brake caliper
Removing the brake pads
Removing the Brake Disc
Carrier bolt
Caliper tied to Spring
Disc removal using bolt
Dismantling the Hub
Torx bolt on hub
Removing the circlip
removing a vacuum pipe
Removing the swivel seal bolts
Splitting the ball joint
undoing the Kingpin bolts
The KingPins are also held in with sticky sealant so you will need to prise them out. The hub will now pull off. Beware, if they are badly worn the hub will be full of stinking grease, oil and water so make sure you can capture the mess in something. This is the bit I hate because of the smell!. That’s water pouring out of the axle! Also shown is a worn out bearing.
The rebuild
The old bearing race
Once clean you can start the rebuild process. The KingPin bearings come in two parts, the race and an outer ring. This ring is still in the swivel and needs driving out. A simple way to drive them out is to use a 1" Imperial socket. I do not have a picture of this process but it is shown in the video. Use the 1" Socket behind the ring and drive it out by hitting it. (picture needed here).
The rebuilt swivel
The greased CV joint
Applying sealant
Fit the disk and fit the caliper (Caliper bolts 61ft/lbs), disk pads and bolt the caliper down in position (Caliper pin bolt 16/ft/lbs)
