King pin bearing change
Revision as of 14:36, 13 May 2016 by Mlines (talk | contribs)
Changing the Kingpin Bearings
Warning Icon.pngThis page is a work in progress - please do not edit at this stage.
  • Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Leaking front swivel
Note Icon.pngClick on images to make them larger
Changing the bearings
  • Assorted screwdrivers
  • Circlip pliers (External)
  • A ball joint splitter
  • 1" Imperial Socket
The Video
Removing the Caliper and pads
Jimny Front Caliper
Unbolting the caliper
Open brake caliper
Removing the brake pads
Removing the Brake Disc
Carrier bolt
Caliper tied to Spring
Disc removal using bolt
Dismantling the Hub
Torx bolt on hub
Removing the circlip
removing a vacuum pipe
Removing the swivel seal bolts
