King pin bearing change
Revision as of 17:36, 12 May 2016 by Leftcase (talk | contribs)
Changing the Kingpin Bearings
Warning Icon.pngThis page is work in progress - please do not edit at this stage.
  • Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement of they are worn)
Changing the bearings
Removing the Caliper and pads
Jimny Front Caliper
Unbolting the caliper
Open brake caliper
The pads are retained by small spring clips, a simple pull on the pads (horizontally away from the disk) should remove them (or gently prise out the pads with a small screwdriver - do not remove the spring clips).
Removing the brake pads
Removing the Brake Disc
The caliper is held on with two bolts at the rear (see below). Release the bolts and tie the caliper to the spring to keep it out of the way.
