- Clicking when in 4WD when turning
- Banging and snatching of the steering wheel
- Loss of 4wd
CV joint information
Suzuki uses two different CV joints in the Jimny. One is straight forward to purchase on the parts market and the other is nearly impossible to source.
- Type 1: 6 balls, 26 external splines and 19 internal splines. - Easy to source (one I have is marked NTN 75LAC CT9U)
- Type 2: 8 balls, 26 external splines and 29 internal splines. - Difficult to source, 6 Ball Jakoparts J2828040 is supposed to fit. (possibly marked NTN EBJ82 although NTN call it an 8-Ball CV)
Note: I can get Type 1 for you, I just do not stock it as too many people bought the wrong one and wanted to return it.
Model | Balls | Inner Splines | Outer Splines | Outer Case Dia | Inner Case Dia | Shaft Dia |
NTN BJ75LAC | 6 | 19 | 26 | 91.6mm | 72.6mm | 19.0mm |
NTN EBJ82 | 8 | 29 | 26 | 91.6mm | 72.6mm | 21.2mm |
NTN 75LAC CV Joint
Changing the CV joint
- Assorted screwdrivers
- Circlip pliers (External)
- A ball joint splitter
- 1" Imperial Socket
The Video
Removing the Caliper and pads
Removing the Brake Disc
Dismantling the Hub
Re-assembly
- You may wish to change the kingpin bearings and oil seals at this point if you wish.
- Again the BigJimny shop sells suitable sealant.
Page last edited on 24/01/2017 by user Bosanek
