4WD transmission failure diagnostics
[PICTURE 1]
As stated, the diagrams are highly simplified and there are a few key points to remember:
  1. The vacuum makes the collar slide, but then is NOT required in order to hold the collar in position. Once the collar has slid in either direction it will stay there through the use of magnets and friction.
  2. The vacuum is used to make it slide both locked and unlocked by changing the route of the vacuum, removing the vacuum tube from a locked hub will not unlock it.
1.
2.
[PICTURE 2]
Figure 1. Location of Vacuum System
3.
[PICTURE 3]
Figure 2. Vacuum Check Valve
4.
[PICTURE 4]
Figure 3. Valve block
5.
[PICTURE 5]
Figure 4. Vacuum Tank
6.
[PICTURE 6]
Figure 5. Vacuum Tubes
7.
8.
[PICTURE 7]
9.
10.
11.
[PICTURE 8]
Figure 6. Lock tube (with brake calliper removed)
[PICTURE 9]
Figure 7. Both lock and unlock tubes (black braided tubes) - the unlock tube is the lower tube that comes down to the front of the hub.
12.
[PICTURE 10]
Figure 8. Vacuum Tubes
13.
14.
Fault finding
15. The table below shows the typical faults:
[TABLE 1]
Checking the system
16. Before progressing through fault finding the system it is worth checking whether the system is really working ok.
  1. Put the handbrake on, put the gearbox in Neutral, start the engine.
  3. Put the transfer box in 4WD, listen for a loud click from the hub and try and turn the car wheel by hand. If the wheel turns then it has not locked.
  4. If it has locked then move the transfer box out of 4WD, listen for a loud click and try and turn the wheel by hand. If the wheel turns then it has unlocked ok.
  5. Repeat for other front wheel.
17. The above test gives you a good idea what is and isn’t working in the system. Using this information the rest of the diagnostics are:
Problem Area (i) – 4WD Switch has failed.
18. You need to get under the car for this. On the back of the transfer box is the 4WD switch. It has a Blue/Black and a Black wire going to it, via a plastic plug. The plastic plug pulls apart by lifting the small tag with your fingernail. Use a piece of wire to short out the connectors on the end of the wire/plug that disappears up into the car. If this makes the 4WD system light come on then the 4WD switch on the transfer is suspect.
Problem Area (ii) – Switch wiring has broken.
19. You need to get under the car for this. On the back of the transfer box is the 4WD switch. It has a Blue/Black and a Black wire going to it, via a plastic plug. The plastic plug pulls apart by lifting the small tag with your fingernail. Use a voltmeter or 12volt bulb mounted on some wire. Measure between the Blue/Black wire and Ground. If the voltmeter doesn’t show 12volts then a wire is broken or the 4WD controller has failed.
Problem Area (iii) – Fuse has gone.
20. The fuse is located in the fuse box under the drivers side of the dashboard, the fuse box changes on different versions of the car.
[PICTURE 11]
Figure 9. Type 1/2 Fusebox – 4WD is FUSE 21
[PICTURE 12]
Figure 10. Type 3 Fusebox – 4WD is FUSE 38
Problem Area (iv) – 4WD controller has failed.
21. The controller is hidden right up under the dashboard on the top right - hand side, you have to pull the fuse wiring to one side and squint up inside the dash. Basically if this is the point of failure you probably should consider fitting manual hubs. However if you have checked the fuses and they are ok and you have a voltmeter then it may be worth measuring some voltage around the controller.
22. If you can prise the connector (E74) from the controller and have a voltmeter you should be able to read the following voltages (with the ignition ON). Only do this with the connector disconnected.
  4. Air conditioning?
  5. 0 volts (earth)
  6. Vacuum switch –Open circuit or earth depending on Vacuum switch
  8. Air conditioning??
  9. Tachometer??
  10. 12 volts (from fuse)
Problem Area (v). - Vacuum leaks from the system
Problem Area (vii). - Pressure switch failure
Problem Area (ix). - Vacuum pipes blocked
23. There is no short way around these problems, you need to inspect the system closely. First take a look at the pipework around the solenoids, it is quite common for the plastic connecters/tee pieces to fracture at the joints.
24. The other common problem is to split or pull a hose off of the hubs behind the wheels.
Problem Area (vi) – Solenoid has failed.
25. The solenoids have power applied when the ignition is ON. Pull the grey wire off each solenoid and short the pin on the solenoid to ground. The solenoid should work and you should be able to feel vacuum if you pull of the vacuum tube and out your finger over the end.
26. First of all – check the little foam filter on the end of the Pressure Switch is clean. With a voltmeter the vacuum switch should be “open circuit” when nothing is happening and goes to “short circuit” when the pressure is correct BUT remember that the system only pulses the vacuum for 10 seconds! If you have the system powered up and functioning correctly with all connectors in place then the “short circuit” will appear as a 0 volt pulse for about 10 seconds otherwise 12 volts will be across the switch.
