Gearbox R72 rebuild
Revision as of 08:45, 18 January 2017 by Sheepish (talk | contribs)
Rebuild
  • Range of impact sockets used to press in bearings
  • 2 large flat head screw drivers
  • a 2 leg gear puller and/or hydraulic press
  • bearing seperator
  • torque wrench(s) to cover 23-90Nm
  • copper or plastic mallet
  • sturdy metal tube of approx 25mm internal diameter, at least 130mm long; but see text for alternatives
Gearbox Removal
Drain Plug
Dismantling
Cover removal
Locating bolts
Counter shaft
Page last edited on 18/01/2017 by user Sheepish
