Gearbox R72 rebuild
Rebuild
  • Range of impact sockets used to press in bearings
  • 2 large flat head screw drivers
  • a 2 leg gear puller and/or hydraulic press
  • bearing seperator
  • torque wrench(s) to cover 23-90Nm
  • copper or plastic mallet
  • sturdy metal tube of approx 25mm internal diameter, at least 130mm long; but see text for alternatives
Gearbox Removal
Drain Plug
Dismantling
With the gearbox on your workbench, remove the 4 bolts holding on the gear change cover and remove. It's sealed with liquid gasket and may need a tap with a soft hammer.
Cover removal
Remove gear shift locating bolts, springs and ball bearings (not shown). The bearings can stick in the shafts. If you can't them out at this stage losely refit a bolt in the corresponding hole so you don't lose the bearing when you start to remove the gear shafts.
Locating bolts
Counter shaft
Page last edited on 11/01/2017 by user Mlines
