Re:Gadget's 2019 hearing aid SZ5
- Thank you received: 320
mikeyw85 wrote: nice write-up. i'm struggling to get hold of those parts. wish the availability over here was a a bit better.
Thanks, yes it's a pain in the bum that we can't get the full accessory selection as standard. I ordered them in from Japan, but the site I used (Japanparts.com) has removed them for some reason (plus it worked out to be silly money with shipping and customs).
JimJimny wrote: Thanks again for another great step-by-step. So how does it sound now ....and does the head unit allow you to adjust/fade the balance between the front and rear speakers?
Thanks. Sounds loads better than before. I thought the dual speaker setup sounded ok, but with my son in the back I had to turn the volume right up so that he could listen as well. The SZ5 headunit allows you to fade front/rear, I'd imagine the SZ4 does too, but not tried it.
- Thank you received: 584
If it is plug-in, I'll fit mine myself, if they have to ness with wires Suzuki will have to do it as I'm not having them refuse to sort out all those electronics that can go wrong because they can blame the failure on my fitting the electrics wrong.
- pixelpower
- Visitor
- mikeyw85
- Visitor
Yeah should do. I'm doing it within next week or so. I think 215 is about the limit for a 5.5" wheel, but it's ok.pixelpower wrote: Do you know if 215 tyres will fit on the steel wheels of an SZ4? I'd like to change mine but not sure if I need new rims too.
www.lvvta.org.nz/documents/infosheets/LV...patibility_Guide.pdf
Scroll down to "Four wheel drive and SUV guide"
facade wrote: Are the towbar electrics just plug in, or did they have to modify the harness?
I'm not sure, I had the dealer fit mine and it looks like a mass of wiring behind the trim panel.
Should be fine, steel wheels are the same width as the alloys.
- Visitor
- Visitor
Full procedure with part details available in the Wiki: www.bigjimny.com/mediawiki/index.php?tit...screen_wiper_control
- Visitor
Well done
