Re:Gadget's 2019 hearing aid SZ5
- Thank you received: 95
Gadget wrote: If you buy the 'Street pack' (Promo ID 004772) you get the sensors and deluxe carpet mat set for £249 fitted.
I was tempted by that offer as I rather fancied the reversing sensors - but the deluxe carpets just don't suit my lifestyle. After hosing down my mud encrusted rubber mats today - I was thankful I didn't pay extra for deluxe carpets
- Thank you received: 320
- Max Headroom
- Banned
- Thank you received: 217
- Andy2640
- Visitor
Anyways, my rubbish jokes aside, it looks very tidy. The picture quality is impressive too.
- Thank you received: 479
Andy2640 wrote: Wow...... James bond himself would be proud.
Thanks Andy, just my phone - OnePlus 6T
- Andy2640
- Visitor
I'm trying to way up what i may want. Picture is good on both, but Gadgets cam looks a fair bit clearer i think. - Worth the extra dosh??
(Scratch noggin).
A nice bonus is that you can actually see when reversing at night now, rather than peering through the gloom of the privacy glass. This was taken in a completely unlit area, with just reverse/brake lights for illumination.
Bulbs used were: www.amazon.co.uk/dp/B072XL5374/ref=cm_sw..._api_i_6cfBCb6DXEDCZ
Before and after shots, both taken with same shutter speed/aperture/ISO and white balance:
In order to get enough room to swap the bulbs, put the car on full lock towards the side you're working on. You then need to remove four push pins (red arrows) and one Philips screw (orange arrow) per side. Screw head is underneath the bumper.
Remove push pins by gently prising the centre section with a small flat screwdriver.
Pull loosened pin out.
Remove single Philips screw beneath bumper.
Carefully bend inner bumper backwards to access light fitting.
Fog and DRL bulbs are both in the same fitting. DRL is at the bottom, fog at the top. First remove the wiring connection by squeezing the fitting and pulling it off. Then grasp the bulb itself, rotate counter clockwise and remove.
Insert new bulb, turn clockwise to lock in place and then reattach wiring harness. Reverse previous steps to refit bumper inner.
- Max Headroom
- Banned
- lee1980
- Visitor
Is the wiki easy to find stuff on and can anyone add stuff?
