Re:Gadget's 2019 hearing aid SZ5
- Thank you received: 584
If it does contain fuel under pressure I suppose I will get a guard, but it seems a bit of an omission by Suzuki if it is so vulnerable, they included an attempt at a fuel tank guard as standard.
- CC Baxter
- Visitor
Chris
- Thank you received: 320
What should have been a very simple bolt-on exercise was complicated by needing to remove the OEM tow bracket (aka 'the plow') first and being unable to move the bumper completely out of the way due to the parking sensor wiring.
Much swearing later, all done and garnished with some rated 3.25T shackles. I considered soft shackles, but the relatively sharp edges of the recovery points made me stick with steel.
- Visitor
- Thank you received: 479
- Visitor
Soeley wrote: Can you turn one of the shackles around please
but then the writing won't match it does my head in too
We need Left and Right handed shackles
- Visitor
Tested up to 70mph and they completely eliminate wind buffeting when the window is down.
Attachment not found
Gen4 Commercial
- Grima
- Visitor
