Blue Jimny 2019
- ColdFire
- Visitor
Jimx5 wrote: I once went dune bashing in Dubai on holiday and the driver lifted the bonnet to let the engine cool off, the engine and running gear was immaculate due to sand blasting.
My concern would be how the Jimny king pins and cv joints set up would stand up to sand blasting as they are not well sealed.
Valid point, i'm sure there is a way to seal the CV and pins better. It's brand new car, i'll make sure to benefit from the 100k or 3 years warranty.
- ColdFire
- Visitor
Lambert wrote: I don't know for certain but wouldn't a software patch be a better way round than unplugging random bits and pieces, a Jimny can't be the only car used locally that won't disable it's traction control there must be a regional specialist who can hack it?
I need to go to few offroad shops and get there opinion. Cars like the Jeep/FJ LC/Nissan Patrol. They unplug the TRC fuse and install a breaker. I looked at the fuse box for the Jimny, there isn't a fuse for the traction control. As far as i'm aware, there isn't a company who cracked the Jimny ECU. Even shops like F performance in Dubai who did the turbo 1.5 Jimny 2019. Did it on standalone computer like Syvecs which is expensive.
I'll pass by few shop and see what can be done. but if i narrow down how to disable tracation by unplugging random bit that will help as a switch can be fitted to connect and disconnect the connection to the plug.
- ColdFire
- Visitor
- ColdFire
- Visitor
Works flawlessly on factory USB and steering wheel control. I love the Jimny logo at the top looks like it came from factory like this.
There was 40A fuse if disconnected turns off traction control/ABS, i'll wire in a switch to have this feature on the go when i'm offroading in the sand dunes.
Thanks
- Thank you received: 320
- ColdFire
- Visitor
It can be purchased thru aliexpress. i got it thru
www.astral-elec.com/2019-suzuki-jimny-in...adio-for-suzuki.html
Few things to keep in mind. It will fit the Jimny that comes without a screen from factory. Also for carplay you need to specify and pay additional 20$ or something like this.
- lee1980
- Visitor
Any idea how the existing stereo is removed as I can't see any screws/clips?
Thanks
- ColdFire
- Visitor
- ColdFire
- Visitor
I would say there are other options available in Japan in which you can buy a surronder/trim to fit other screens from Pioneers and Kenwood etc... depends which way each one want to go.
