Soeley's 2019 Black SZ5
- Thank you received: 320
- Thank you received: 479
- MrPaynterZA
- Visitor
I wish you many happy miles!
- Thank you received: 584
DRLS On
Side Lights (Note: DRLS stay on)
Dipped Beam
Fog Lights
The cover is held on with a locking wheel nut, underneath are three wheel nuts holding the wheel. In my eyes if the plastic cover was forced off, the wheel is then not protected by a locking nut. Wondering if the locking nut should be on the wheel and std nut on the cover?
Any thoughts?
Soeley wrote: Also a nice surprise, I removed the spare wheel cover to find an alloy wheel under there, was sure it would be a steel wheel. Not sure what to do now, leave the cover on, remove it or get a custom cover?
Any thoughts?
I wouldn't worry about it (Unless you are from South Africa). The size tyre is not common, so shouldn't be a target, and I doubt there are many thieving Jimny owners
- Themooingman
- Senior Member
- Thank you received: 14
Rigid cover is quite nice but with everything I guess it’s eye of the beholder stuff.
2019 Gen 4 Jimny SZ5 in Silky Silver. Parking sensors and Rear Camera, floor mats pack and Rigid tyre Cover
- Thank you received: 95
As a side note the Handbook shows an internal release for the rear door (might see if one is available on the net) on the trim panel you can see there is a knock out for fitting the release.
Once the cable was pulled through to the back, I managed to feed it down inside the C post and pull it through the wiring gaiter hole in the rear door frame, through the actual gaiter and into the door cavity. Using some stiff wire with bent hook on the end the cable was pulled through and out next to the wiper motor bracket.
I realised if I trimmed down the connector it would fit through the heated rear window wire hole.
The camera cable runs up along with heated rear window wire, and then fits just nicley in the gap between the window frame and the rear glass, up and around to the camera.
Minimal cable on show, how I like it. Next job is to hard wire the actual camera so it is not kept plugged into the front power socket.
