Soeley's 2019 Black SZ5
- Thank you received: 1759
- Thank you received: 96
- Thank you received: 475
DAGZOOK wrote: Soeley, did you have to reduce the length of the bolts that Jimnybits supplied? They looked long to begin with. Very solid looking guard, good value for money too.
No, everything is as supplied. No trimming needed.
- Paxijimny
- Visitor
One fuse box is permanent live the other ignition live via the relay. The relay is tapped into the front power socket for activation.
The next stage will be to hardwire my dashcam into it and a phone charging point which I will have permanent live.
So this is the board has I had it fitted to my Toyota iQ.
A bit of rearranging and it now looks like this to fit behind the glove box of the Jimny.
A spare stud poking out the under felt was used to secure the bottom left corner. They are like a self tapping thread so the buckle from a cable tie pushed on nicely.
In situ, the top right is sandwiched behind the fan blower mount and bracket.
Power Magic Pro wired in and Dashcam connected all wires now hidden away up the A-post and behind the headlining.
- Visitor
- Thank you received: 319
Hope you don't mind some daft questions!
Do you have any details on the parts used to construct it?
On the wiring front is the following setup correct?
- Live (direct from battery terminal?) comes into permanent live fuse holder
- Live goes from perm live to relay (connection 85?)
- Live from relay (connection 86?) goes to switched live fuse holder
- Relay (connection 87?) goes to earth
- Relay (connection 30?) connected to live of front 12v socket in dash for activation
Does the earth wire for the relay only need to be the same gauge as the activation wire on terminal 30?
Are you just taking the live feed for each accessory from the new fuse blocks and then earthing each accessory separately? I was considering something like this, taking the earth direct from the battery to a common earth rail, with each accessory taking their earth from the fuse block.
www.amazon.co.uk/dp/B07FT1Z4MS/ref=cm_sw...t_dp_U_NWiJDbTNVZM58
Gadget wrote: That's a great setup Soeley, really neat. It's motivated me to sort out the tangle of add-a-circuits that's hiding under my dashboard
No daft question Gadget
To be honest I can't remember where I got the bits from as it must be about 6 or 7 years since I initially made it, but probably Amazon or Ebay. But basically:
2 x 4 way fuse boxes with common feed like the one you linked.
30amp relay with relay holder (could do it without the holder).
The cable ties are the ones that have a tang on them to fasten to the board.
The actual board is made from a plastic A4 clipboard.
The wiring front you have guessed correct (not sure of relay terminal numbers though).
Yes the earth wire is the same gauge as the activation wire.
Yes each accessory will be earthed separately, there are two earth point behind the passenger foot well trim.
