BigJimnyMeet 2024
Paras red 2002 jimny jlx
- Max Headroom
- Banned
- Thank you received: 217
29 Nov 2018 12:46 - 30 Nov 2018 21:31 #198355
by Max Headroom
Replied by Max Headroom on topic Re:Paras red 2002 jimny jlx
I really like those 'flat' blades by Bosch - I think Valeo do them as well. They just seem more effective at doing the job without all the screeching and juddering. I had major issues with that on the Meriva we had, and the flat blades cured the problem completely, after putting up with it for years, and thus converted me!
Last edit: 30 Nov 2018 21:31 by Max Headroom.
- paradox1001
- Visitor
30 Nov 2018 13:57 #198441
by paradox1001
Replied by paradox1001 on topic Re:Paras red 2002 jimny jlx
- paradox1001
- Visitor
30 Nov 2018 16:11 #198445
by paradox1001
- Thank you received: 1759
01 Dec 2018 06:22 #198461
Replied by Lambert on topic Re:Paras red 2002 jimny jlx
That's just side lights? Impressive.
- Max Headroom
- Banned
01 Dec 2018 09:01 #198463
by Max Headroom
It kind of 'brings it up-to-date'
- paradox1001
- Visitor
01 Dec 2018 11:34 #198470
by paradox1001
Yes lambert that’s just the side lights on.
It certainly makes it look a lot Crisper max
The only thing is the new bulbs have shown up clouding on the headlamp plastic so I’m going to have to get some cutting compound on them.
- Visitor
01 Dec 2018 14:39 #198475
Replied by Daniel30 on topic Re:Paras red 2002 jimny jlx
I used autoglym on mine worked a treat I don't think you will need anything to heavy on them
- Thank you received: 82
01 Dec 2018 15:08 #198477
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic Re:Paras red 2002 jimny jlx
Para leds from aliexpress?
- Max Headroom
- Banned
01 Dec 2018 15:57 #198481
by Max Headroom
Para - get yourself some acrylic polish such as Greygates plastic polish. T-Cut will do it and so will Brasso, but there may be chemicals in those that could potentially rot plastic.
If they are really yellowed and pitted, I've seen several headlamp renovation kits in Halfords by Meguiars and Autoglym to name but two. The kits consist of acrylic polish and Micromesh abrasives to get the worst out of it.
Or you can buy a full Micromesh kit on eBay - but those aren't cheap.
It sounds horrendous using abrasives at first, and you'd think you are about to finish up with a frosted glass effect, but you don't! They come up like new!
- Cremator1
- Visitor
01 Dec 2018 18:25 #198489
by Cremator1
Replied by Cremator1 on topic Re:Paras red 2002 jimny jlx
When u put them in the indicator don’t they rapid flash
- paradox1001
- Visitor
01 Dec 2018 18:47 #198491
by paradox1001
I’ve used facella g3 compound to sort a set of Passat headlamps that were worse than these
I’ve still got a litre bottle of it in the shed
I’ll give autoglym paint restorer a try first and if that doesn’t work I’ll use the g3
The leds were from eBay
I’ve only fitted them to the side repeating indicators at the moment the front and rear are still bulbs but it flashes at normal speed.
- Cremator1
- Visitor
01 Dec 2018 18:51 #198492
by Cremator1
Ah ok have you tried led bulbs in the other indicators
Time to create page: 0.162 seconds
