BigJimnyMeet 2024
× Tell us about your Jimny and post some pictures! Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Ola`s jimny project
08 May 2018 08:50 #192502 by yakuza
www.bigjimny.com/forum/7-jimny-technical...ain-grrrr.html#71942
Remember to check your drive shaft for leakage. Most likely you have the same as mine.
Seems no Norwegian cars have been doing the recall and service bulletin for this.
The following user(s) said Thank You: OlaGB
  • OlaGB
  • Visitor
  • Visitor
08 May 2018 11:24 - 08 May 2018 11:25 #192506 by OlaGB
yakuza wrote: www.bigjimny.com/forum/7-jimny-technical...ain-grrrr.html#71942
I check it every time i'm under the car, no leak to be seen yet!
But thanks for the heads up :)
Last edit: 08 May 2018 11:25 by OlaGB.
  • OlaGB
  • Visitor
  • Visitor
08 May 2018 12:44 - 08 May 2018 12:46 #192510 by OlaGB
Winch mount done.. Pleased with the result!
Not sure if ill change to syntetic rope or just buy a fairlead for steel wire yet.
Modified the JB mount, moved the winch as far in as i could, and cut/welded the fairlead wall closer to the winch.
Had to remove the A/C fan to make room, but thats it..
Fitted the reg plate on the bumper using 3M duallock, so i can remove it when i need to..
Protects the winch and wire from alot of mud, salt and sun..
Even with a fairlead glider plate, it sits within the bumper.. Just the towing points sticking out..
Last edit: 08 May 2018 12:46 by OlaGB.
  • Daniel30
  • Visitor
  • Visitor
08 May 2018 16:16 #192519 by Daniel30
Some great information guys and that winch install is spot on...
  • MadsV
  • Visitor
  • Visitor
08 May 2018 16:31 #192521 by MadsV
Thats nice, a little Z2S silver where the winch comes out and it would look like a piece of the bumper!
  • OlaGB
  • Visitor
  • Visitor
08 May 2018 18:01 #192524 by OlaGB
MadsV wrote: Thats nice, a little Z2S silver where the winch comes out and it would look like a piece of the bumper!
Hoping for sucsess with a silver fairlead :)
09 May 2018 05:53 #192536 by yakuza
OlaGB wrote: Winch mount done.. Pleased with the result!
Nice and tight!
No AC fan? Will that make the AC less effective only when not moving maybe?
I would still try to get a rope to replace the wire.
  • OlaGB
  • Visitor
  • Visitor
09 May 2018 06:27 #192539 by OlaGB
Nice and tight!
Yes, thats what i`m hoping for, that the AC will work as before unless i`m standing still.
There is room for a smaller fan , but i dont care much about it..
If the motor shows to run hot in offroad use, i`ll make a manual electric fan instead..
Syntetic rope looks like the way to go for safety! But there`s pro`s and con`s for both..
Theres everything from heat issues, alu fairliead that gets damaged if the hook is pulled into it (needs to be hooked to the tow point at all times), and contamination from the road etc..
Both alternatives probably needs a sack over the winch for longevity and less maintenance.
11 May 2018 21:37 #192608 by Busta
Bit late noticing it, but nice to see somebody has used my bolt in the hub locking technique!
  • OlaGB
  • Visitor
  • Visitor
12 May 2018 03:34 #192611 by OlaGB
Busta wrote: Bit late noticing it, but nice to see somebody has used my bolt in the hub locking technique!
Found the idea on Youtube (
) , but didnt know it was you! :)
Worked just as supposed, and was a very quick fix! Thanks for putting it out there.. (If the YT vid wasnt you, it might be based on you`re idea anyway)
12 May 2018 09:14 #192613 by jackonlyjack
That's a good quick fix idea Busta ;)
6.8mm drill is correct size for m8 tapped thread
12 May 2018 16:50 #192627 by Busta
Yes that's me. I've put a few random Jimny videos on YouTube. Nice to see they are useful :)
Yes Jack, 6.8mm is correct but in this instance it is not critical. There is very little force on the bolt.
Powered by Kunena Forum
