Ola`s jimny project
- OlaGB
- Visitor
SSS motor is in, on stock exhaust and intake.
Std Exedy cutch on stock flywheel, and new crank pulley, water pump, thermostat, and gaskets.
Motor runs fine, allthough a bit dissapointed on power. A litte stronger on 235`s, than stock on stock tires for sure, and it runs flawless with no issues other than some occasional ign knock above 4500rpm if i push it hard for a long time.
No OBD codes, but i think its a bit lean up high, and rich down low.
I wont be tuning it just yet, as I`m conviced the motor doesnt breathe well, so there might be some plans for exhaust and intake upgrades
I also installed HD mounts for the transfer, and did a oil change on the gear box since i rebuilt it 2k km earlier.
Nothing much to see though..
I also got the air locker and compressor in the mail this week, but i wont start installing it before next month, due to going away for work..
Same goes for transfer gear`s.. Might be installing winch before i leave though!
- MadsV
- Visitor
- OlaGB
- Visitor
MadsV wrote: Nice! You probably have to drive it for a while to notice where you actually have more power, but more air should help
I was done on tuesday, about 12h work in total over 2 days..
Been driving 300km with it allready, and done some road tests, changed spark plugs, obd logging etc..
I also got a G-tech meter to do hp/nm tests before/after, that also tells me the same i allready felt.. An upgrade without doubt, but not even cloae to SSS power yet.
But ill get there, or atleast alot closer, just have to throw more money and hours in it.
So far the best part is the extra torque, so i can drive away from standing still, without habing to rev the motor..
And it stays in 5th gear in most normal hills, where it lost speed in 4th before.
- Thank you received: 332
is it not possible to use a G16 16v header, and cut off the manifold and reweld to a m13 or m16 manifold?
the difference in placing of the ports cannot be that much..
I could also get a few blanks for manifolds laser cut from 10mm steel plate i guess.. price about 40-50£ each.
postage from Norway is completely bonkers so no way it will be affordable to export sadly.
- OlaGB
- Visitor
Keithy wrote: Ola....did you get the SS exhaust manifold?
I bought a 4:1 collector to turn the original manifold into a 4 branch/remove the first cat......I'll get a picture.
Sadly, no, only the intake.. But the intake looks so far from stock, that i dont want to use it for now.
The more i think about it, the more i believe the exhaust holds back. The more aggressive cams in the SSS needs a better exhaust as well.
And i think the header is the biggest issue. I actually think the pre VVT header would be better than the stock.
I`m considering using a exhaust they use over in south africa, the guys at 4x4community.co.za forum, a pre made full exhaust with a 4-2-1 header.. The only system i can find several dyno proof of working really well. No cat though, only a "cat fooler", might swap it out for a cat.
About 500 GBP + shipping and taxes, so not extremly heap, but cheaper than only getting a header made over here so...
the flow in the intake and TB, and thru the exhaust are balanced and made to fit to make sure the air and fuel mix is optimal. Changing only one item like the TB is often not any help as putting a wider TB there will slow down the air thru it in most cases.
Bad air/fuel mix can also make ingition pinging?
When we change from 1300 to 1600 there is almost 20% more air that should be going thru it?
If we do not change the diameter then it will have to flow faster and bends and obstructions will have more significance to the optimal flow.
The cylinder head will probably play the largest part in this.
The lack of high end power suggests that the flow is really the problem and when removing the cat has little effect i think the intake is the place to try to do something in my case..
- OlaGB
- Visitor
If the exhaust doesent help evacuate the gas/heat, the next stroke will be less effective.. If the intake is to small/bad flow, the exhaust will not be flowing well out of the cyl, and there will be less fill of new oxygen/fuelin the cyl on next stroke..
Even worse on the more agressive cams in the SS motor i reckon.
I`m thinking M18a intake/throttlebody + full exhaust, that should do it.
- Thank you received: 305
These are going on a 1.3 vvt, the existing induction and exhaust system are massively restricted, I'm hoping to get 1hp - 1cc, it will take cams and headwork to get there but I think the little lump is ace
Existing tb is 46mm for four ports, these will give 38mm to each port and in a straight line.
The exhaust is is even worse, manifold/front cat is horrid and prone to collapse and restrict. The system is poor.
An improvement in air flow through the engine will to a certain extent be managed by the existing fuelling system but it could loose power because it can't now be timed and fuelled to an optimum. Adjustments to ignition timing and fuelling, mapped live under load, is the only way to restore "balance" and get the improvements that the changes have the potential to deliver.
Very few of us would want to drive an engine that is tuned purely for peak power, I spent a year driving a classic mini with stage 4 head 310 cam and a weber 45, 107bhp at the wheels. Every set of lights was a nightmare, you needed 4000rpm just to slip the clutch and then you launched it.
It looked like you were racing from every stop start. Only ever sounded right at half throttle or more, peaky - lumpy just generally not nice.
A 4x4 wants a broad spread of power across as much of the rev range as possible.
You can only manipulate the power/torque curves on an EFI engine thru the ecu. The standard ecu does an amazing job, I've seen 1.3, 1.5, 1.6 and 1.8 running on it thru these pages, bloody amazing....... but if you can't overwrite it for a tune that suits the specific modifications, you loose in many ways.
The 1.6 vvt will respond well to exhaust and induction mods BUT you've got to be able to programme the fuelling and ignition. Over 200bhp is often seen in swift rally cars, I would guess that somewhere around 150-160 should be available without head mods or cams
It's a package deal in my opinion, you get some benefit from improvements to induction and exhaust but they will only give their true potential if mapped correctly. So fitting an after market ecu will probably be necessary to release the engines potential.
Great thread.
sniper
- OlaGB
- Visitor
sniper wrote: I am planning to run throttle bodies (danST) and a 421 header with a 2" 200 cell CAT and straight thru system. ME221 ecu to sort the fuelling as the VVT denso can't be overwritten easily.
You can only manipulate the power/torque curves on an EFI engine thru the ecu. The standard ecu does an amazing job, I've seen 1.3, 1.5, 1.6 and 1.8 running on it thru these pages, bloody amazing....... but if you can't overwrite it for a tune that suits the modifications, you lose power and drivability.
Great thread.
sniper
I agree on pretty much all of youre post
I am going for a dyno tune, maybe in a months time.. Just want to be "finished" mechanically first, as its expensive to dynotune.
They claim they can fully tune my stock ECU, so that should be the best solution for me and my setup.
I want more top end ofcourse, but just as important is to tune the low end for it to handle low rpm situations better (which now is alot better allready than on the 1.3).
You`re setup with ITB, needs a standalone i think, mostly due to the loss of common map sensor? I think you need to map against the throttle angle sensor and not map sensor (both can use MAF sensor ofcourse, but i suspect you plan to run without a collector intake in front of youre ITB`s?).
You will get alot more throttle response, but also alot less resolution in youre low throttle positions.. This i do not like for a offroad car.. But it`s possible to get some of it back, if you use a completly different profile on the throttle cable gear, to slow down the movement alot in the low end.
- OlaGB
- Visitor
Gear box allready has this from stock, but i`m going to do the transfer also , when i pull it out for re-gearing. No room for doing it in the car.
Front
Rear.. Dont like the "water trap" though, might be running it individually straight up to the rear of the car instead to avoid this, if it shows to trap condense water over time.
I think it will make much more use of low range than it does now, but as you say, it will spin up like a rocket. That will be a negative that I hope to be able to tune out, possibly having a two stage tune, one tarmac the other for low range.
I will ask the supplier if he has ever had reason to dampen throttle response and see where we go.
Thanks for the nod, I probably wouldn't of considered it as an issue until I'd buried my wheels........
sniper
(just had a look at some S1600 rally engines and CTC have 178bhp@8750rpm, albeit with forged internals but it shows the engines got plenty of potential)
