Ola`s jimny project
- Visitor
- OlaGB
- Visitor
Finished the weekend off with installing the last parts i had lying around, that just has been postponed for several reasons..
Fuel tank bash guard, and long bolts through rear shock mount..
The rear shock protectors (JB) has taken some beatings allready, and done a good job!
I`m getting really happy how the little Jimny has gotten now.. But theres always some new plans and dreams right?
Probably looking at light`s next..
Underside pictures. Alittle heavier than i would like it, but protection is important. And the weight sits low.
- OlaGB
- Visitor
Kenwood dbx5015dab headunit
5 1/4 Jbl GTO component set front
5 1/4 JBL GTO 2way rear
3x Luminalight X80 LED (very powerfull)
2x Luminalight slim 25w (flood rear)
2x quality LED bulbs for stock revers light
Stereo will be setup with a powerfull amplifier, and probably a subwoofer as well.
- OlaGB
- Visitor
1 spotlight dead on arrival, new is on the way. Using 2 meanwhile. Still to do rear/surrounding lights.
Speakers, headunit and a powerfull 4x100w rms amp installed, sounds ok now but really lack lowbass still. Subwoofer will be next.
Also found a new spot for my Autool display, and i kinda like it!
Some pics..
And some light pics:
Lowbeam (Phillips xtreme) ;
High beam:
High + 2 LED spots: (spot nr 3 not working)
As always, very hard to show how good the lamps are.. Phone locks onto center of light, but the lightflow is even wider that in the photo..
what sub you going for? there is a few that might fit under the other seat...
- OlaGB
- Visitor
Made a nice little loop on the cables to it, so the seat can move back/fwd wothout issues. 4 gauge power wires, amp pulls amps
Going for a full size sub, got a great deal on a new Kicker 10`` L7..
Will make a sealed custom box in the rear approx 30-35cm wide..
The other seat has the diff lock compressor hidden under it!
- OlaGB
- Visitor
- Thank you received: 651
Just be aware how much heat comes up to the vents
i would advise trying to blank off behind to reduce the heat
Has it may get hot enough to effect the electronics
- MadsV
- Visitor
When did you get a snorkel??
- OlaGB
- Visitor
MadsV wrote: Nice install. I need more low bass also, gonna build a small woofer for my two 4” woofers
Snorkel, hmm i think i installed it in june or so.. I dont think i posted any pics of that
Low bass/sub box.. Done lots of measurments today, and bought some material to build the box..
Ive also started to copy youre compartment box in the floor, to keep tow ropes, tools etc in..
The subwoofer box will be approx 29 liters.. Around 35cm wide, 36cm deep, and around 40cm high making it approx flush with top of the rear seat when you have that compartment underneeth. Sub will be on top pointed up. Rear door cover will be replaced with a flat plate to make room, and generally to make boot space bigger. The rear panel wastes alot of space.
Going to be a tight fit, but it will also leave me with 55x35cm floor space for shopping beer
Ill do it so the sub can be removed within seconds when i need more space, allthough this is not the car i use when i need alot of space
- MadsV
- Visitor
- Thank you received: 1759
