CAE's Daily Jim
- Caelite
- Visitor
- Caelite
- Visitor
Unfortunately fitting my 1.5" spacers have been thwarted a bit by the bolts on my front shocks being completely siezed in, wouldn't even shift with my 18" breaker on them. I might do the backs myself then chuck the fronts in to a shop for someone to rattle gun off.
Also due another service, waiting to see if Martin gets some more blueprint filters in stock.
- Caelite
- Visitor
New backbox is getting fitted tomorrow & he's patched the little hole in the bracket, thankfully he isn't advisorying, or worrying about the angrily flashing 4WD and 4-L lights on the dash, has said he will even take a peak at the t-case & see if he can get them to turn off well he has it on the ramp.
Caelite wrote: Well, the Jimnys been a pain in the ass this month, first the 4WD vacuum system failing intermittently, then the transfer case position sensor packing in. Now it's chucked an MOT fail over a leaky backbox & a rusty panhard rod mount (not something I've ever heard of failing on Jimnys, a little ~20x10mm hole developing in the middle of the panhard bracket on the driverside).
Has it got an MOT now?
How did you resolve the emmisions failure? Could the tester find the Jimny on the system then? If not it gets tested on the generic old limits and would be unlikely to fail. If it does the CAT will have had its day.
- Caelite
- Visitor
Have a bad feeling the solenoid in the transfer case is completely goosed though. Need to have a proper look at it, but waiting until temperatures get back into the positives though.
- Caelite
- Visitor
Decided instead of going for another Jimny one, like I did before, to look for alternative options. Found exactly what I was looking for from a guy called 3d-4x4 (3d-4x4.com/products/suzuki-jimny-aerial-...a-direct-replacement) arrived today, along with some new seat levers for my rear seats (both of which I have snapped off). It's a wee bit rough around the edges where it's been printed, but it all feels solid. Was aiming for my levers to match the yellow on my Recaros, they aren't the best of matches but will do (maybe should have ordered gold instead of hi-vis yellow).
Haven't popped the levers on, have yet to figure out how to get the old plastic sheathing off.
Also, have ticked her over 140k miles, was on track for 150k this year but unfortunately recent events have put a damper on some of my site visits.
