BigJimnyMeet 2024
Blake's Jimny
- 1066Boy
- Visitor
29 Nov 2017 07:07 #186845
by 1066Boy
Replied by 1066Boy on topic Blake's Jimny
The grill makes the Jim looks a lot more modern. I like it.
- Darthblaker7474
- Elite Member
- Thank you received: 19
04 Dec 2017 16:42 #187015
by Darthblaker7474
Replied by Darthblaker7474 on topic Blake's Jimny
- Darthblaker7474
- Elite Member
10 Dec 2017 19:53 #187300
by Darthblaker7474
We got a shed load of snow here overnight, and of course the local council decided not to grit the roads. Was no match for the wagon though
- Darthblaker7474
- Elite Member
19 Dec 2017 22:30 #187647
by Darthblaker7474
- Thank you received: 1759
20 Dec 2017 04:59 - 20 Dec 2017 05:00 #187653
Replied by Lambert on topic Blake's Jimny
Last edit: 20 Dec 2017 05:00 by Lambert.
- Darthblaker7474
- Elite Member
20 Dec 2017 10:58 #187659
by Darthblaker7474
20 Dec 2017 12:51 #187666
While it would be cleaner it also renderw the refitting of the bars in future an impossibility so I am sticking with the plastic dome nuts.
- Darthblaker7474
- Elite Member
15 Jan 2018 00:51 #188397
by Darthblaker7474
Been busy recently, so not much time for any cleaning, let alone mods
However I did get some new parts of eBay from a 2016 model
Didn't get the airbag as it was knackered to say the least, but I was quite chuffed with the fascia as it comes with the flap on the 12v socket too.
The only downside is there must've been a revision with the wiring harness, as the new clocks have one plug, where as my current ones have two
I'm thinking fitting them will be a custom wiring jobbie.
- CharlesS
- Visitor
15 Jan 2018 15:06 #188407
by CharlesS
Replied by CharlesS on topic Blake's Jimny
Nice looking vehicle.
In the near future I plan to purchase a Jimny as a daily driver in the Philippines.
I see that you have a rear disc brake conversion; who is the maker, where did you purchase it and did you do the installation ?
In the states presently drive a 1998 Jeep Cherokee on which I installed a disc brake conversion; the difference in braking performance is like night and day.
- Darthblaker7474
- Elite Member
15 Jan 2018 23:47 #188426
by Darthblaker7474
Thank you
I got my rear disc conversion from JimnyBits which I believe is based in the UK. In addition the the linked page, you'll also need extended brake lines, discs, pads, and calipers. The most commonly used are off a Renault Megane, and cost me about £100 including pads.
Depending on what size wheels you have you may also need spacers, I found that with the standard 15 inch steel wheels there was some grinding against the caliper. I've since upgraded to alloy wheels so I need to see if I need spacers with those anymore, which are 32mm at the moment.
And similar with your Jeep the difference was definitely noticeable, it still mainly uses the front brakes, but stopping is a lot more "level". However I do find that the ABS does tend to kick in a lot more.
- CharlesS
- Visitor
22 Jan 2018 00:50 #188692
by CharlesS
Db,
Thanks for the disc brake conversion information.
Charles
Charles
- Darthblaker7474
- Elite Member
03 Mar 2018 17:42 #189897
by Darthblaker7474
Got my fire extinguisher (kind of) fitted the other week
More recently I've been having plenty of fun in the snow
Could definitely do with some more rugged tyres though
Time to create page: 0.159 seconds
