Re:My 01 Jimny, another Norwegian
- Venter
- Visitor
- MadsV
- Visitor
- Thank you received: 332
Also changing the rear master cylinders and shoes as the handbrake hangs up in reverse. All sticky and gooey in there from leakage and dirt.
- OlaGB
- Visitor
- MadsV
- Visitor
I can post links with the parts if you like, will probably make a bigger post with details when i’m fitting it
- OlaGB
- Visitor
MadsV wrote: Ordered complete front brake kit for diesel jimny at brakes.com with ebc greenstuff pads. And ordered calipers from Meca, brand FTE, for 5 door vitara g16b.
Aha.. No need for details right now, but it`ll be interesting to read youre post afterwards!
Brakes sure could be better than stock.. Lets hope youre brake bias still will be ok, or are you doing rear too?
- MadsV
- Visitor
- MadsV
- Visitor
From memory, the vitara caliper piston is 52mm diameter and the SJ where 46mm. I have no idea what diameter the jimny is.
- MadsV
- Visitor
- Thank you received: 1759
- MadsV
- Visitor
