Re:The Jimny of the Yakuza
- Thank you received: 1761
- Thank you received: 332
Sent fra min E5823 via Tapatalk
- Visitor
- OlaGB
- Visitor
yakuza wrote: Managed to get one of the last second hand gearboxes in Norway for 5000 Nok approx 600 pounds. Only 40000km on it. 2013 model. Not too bad. New exidy clutch also ordered, hoping it will fix my 2000 rpm vibration. Hoping it will not be too long before they get here.
Damn, good find! Good price as well..
Standard exedy clutch, or safari tough?
- MadsV
- Visitor
standard clutch will do. The other smelly one did ok for a year, and now I'll soon gear down the transfer case as well..
- OlaGB
- Visitor
Maybe you`re inspection cam could reach in to some of them through filling/draining / sensor holes?
OlaGB wrote: So, when are you cracking open the 2013 box to check if it`s closed or open bearings in it?
Let's see.. If i drive 8000km a year I would be opening it for inspection some time around early days of 2026
But i should be able to put the camera inside. have to swap the sensor and will loosen the filler caps of course. Pictures to come!
if it doesn't look good i could return it as well..
At work, we put 1" plugs for camera or hatches big enough for hands on the gearboxes on clever places to make it possible to look or work inside without a total dismantle..
That is a 6 hour drive south.
It was close to Oslo on the 12th so the postal service must have sent it westward instead of north to me.
The clutch is still in transit somewhere between Hamburg and Norway so no immediate hurry though..
- mdog18
- Visitor
Vibrations around 2000rpm -Gone
Trouble with shifting into reverse and first gear when standing still -Gone
Grinding sound from gearbox -Gone
Oil leak from rear of gearbox -Gone
Open bearings in Gearbox -Gone
Had an endoscope camera inside the gearbox and found a closed ball bearing with a green side so this is the upgraded type.
It's like a new car. The gearshifts are more precise, feels tighter, shifts more easy.
Clutch gripping point is now in the middle of the pedal way instead of in the far out to try to make it release properly.
Pretty fiddly job this. Had to postpone it for a week while I was laying tiles in our washroom so I could get the washer machines back in from the Hallway. Couldn't go out to the garage with a family running out of clean clothes.
And as a bonus, plastic steering wheel -Gone.
Changed to a leather steering wheel from the same car as the gearbox.
