BigJimnyMeet 2024
My Jimny named R&B
- Thank you received: 651
06 May 2018 13:53 #192439
Replied by jackonlyjack on topic My Jimny named R&B
06 May 2018 16:56 #192442
Replied by Riccy on topic My Jimny named R&B
thats a lot!
06 May 2018 17:37 #192446
Yes matey the hub,swivel and cv where packed solid
Took a while to clean them out
- Thank you received: 1759
07 May 2018 06:30 #192461
Replied by Lambert on topic My Jimny named R&B
And somebody will have thought they were doing a good job!
12 May 2018 15:43 #192624
03 Aug 2018 14:53 #194812
New boots are a little bit too big
Getting a slight rubbing on front chassis to body mount
What are my options i have big hammer
Would be nice to know what others have done
Jack
Jack
- Thank you received: 305
03 Aug 2018 15:52 #194813
by sniper
Replied by sniper on topic My Jimny named R&B
R&B looks well with them on pal, a bit of grinding and a bit of welding.....
It looks quite easy to triangulate / support the mount and allow you to cut away the projection, what an MOT inspector will say I don't know.... I can cut and prep the plates but can't weld anymore. Local garage will weld it for £80 if needed, they are testers too so I can have a word about welding around the mount, again if needed.
sniper
sniper
03 Aug 2018 16:46 #194814
I put a ratchet strap around the body mount's two sections and squeezed them together a bit (maybe 1" all together).
Also installed some sexy Redacted extended bump stops, which seemed to help just as much with the same problem.
What size are they? look great on the GV rims
03 Aug 2018 20:01 #194816
225 75 16 i also have Redacted bump stops fitted too
04 Aug 2018 06:12 #194819
so thats a 29.3" tall by 8.9" wide tyre then, compared to the 31x10.5 i have, i am surprised you have a problem with them catching.
Different rims, offset and lift maybe? for reference my rims are 15x8 et -0, theres 30mm wheel spacers and 4.5" lift on the springs
04 Aug 2018 07:13 #194820
Could be that i have 3" castor arms with a 2" lift. Therfore the axle is pushed forwards
Being over casterd it drives so nice
I have got 4 Honda crv springs so i can go up some
04 Aug 2018 07:46 #194821
That will explain it then! I too have 3" castor arms, which will be pulled back by inference then
