My Jimny named R&B
- Thank you received: 651
Keithy wrote:
Heyup Jack, how is the "armrest" fabric held on?jackonlyjack wrote: i have a couple of reasons why i did it
1 being short
2 the bucket seats
will put template to one side just in case someone ask's for it
Jack
I'm wanting to raise mine as the arm out of the window season is over.
I'm contemplating making some door pockets which could actually hold something more than a slip of paper..Possibly a beverage of some kind...I'll wager you'd be brave enough to fit some, want me to save some prototypes for you?
Mmmm i like prototypes Keithy pm me some piccy's
i did not realise there was so many places for water to ingress
till all the paint started to run out
Jack
- Gazguzzler
- Visitor
Phil
Is it has these on each end
I shortened it a little and already had a tight 1D 90degree bend wasn't to much of a job
Not to sure whether i like the exhaust note
it's not stupid loud
Ebay item number 291940019493
I cut the flange off bent long end
Then welded it to the short straight before the box
Other end i cut off see picture
That will be used on my next silencer if i chose to remove the one fitted
Jack
main reason is for cleaning the under side
not leaving any trapped mud and better air flow round body mounts to dry them
body mounts have minimal rust
but gave them a scrape painted with buzzweld CIO
lifting the front was a bit un nerving (never done this before)
as i followed the blog on little red
had to remove more wires and cut ty-wraps
as i went up
on a plus side it all worked when back together
New old bonnet now on with additional stickers
just need more sunshine so i can continue my quest
Jack
- Visitor
- Thank you received: 1759
