My Jimny named R&B
- OlaGB
- Visitor
- Thank you received: 650
- Max Headroom
- Banned
- Thank you received: 217
....you could always glue some leatherette trim over them
RTV = Road Trim Vehicle? NL4x4 has that class and it means = something which could pass an MOT (just). expect a risk of going on your lid
Maybe 2020 will enter CCV custom class vehicle but will need roll cage and a lot more demanding
- Visitor
- Thank you received: 82
jackonlyjack wrote: After wifey got me a dash cam for my birthday
Had to make few modifications as I can't be doing with anything stuck to windscreen
Also a new interior light nice and bright
Happy with the new additions
Jack how did you fit the interior light to the headliner and did you wire it into the courtesy light under the rear view mirror? Im king of following your work Jack or kind of on the same wave length I seem to be thinking the same way about the same things .
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
I cut a square hole half inch sized used a flexible tent pole pushed it towards where the old light was
then tapped wires to thin steel rod pushed it along side to get wires through
connected to connector for old light (just be aware it only operates with door open)
The back of light is nice and flat so i used hook side of some velcro glued to light
pressed it to roof liner and it's never moved since
Best thing i've done it's so bright
Jack
jackonlyjack wrote: The lamp is a ring one same as my reverse light
Jack
Going to do this mod think its a good option, the door will always be open to get gear out.
- Max Headroom
- Banned
jackonlyjack wrote: The back of light is nice and flat so i used hook side of some velcro glued to light
Velcro is great for a semi-permanent attatchment of lightweight items. I've used Velcro extensively on internal trim panels on executive jets. The only weak-link is the glue attaching it, which could eventually fail particularly when it gets very old and spent lots of time in very hot climates.
Great write up
My other like is 3M acrylic foam tape this is how the rear fog and reverse lights are held on
Jack
