BigJimnyMeet 2024
× Tell us about your Jimny and post some pictures! Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Galactic Jimny
  • jim
  • Visitor
  • Visitor
15 Oct 2015 15:39 - 15 Oct 2015 19:01 #153712 by jim
Replied by jim on topic Galactic Jimny
My dipstick was cracked where the hole is, apparently it's a common thing but luckily the site store has them in now as I didn't want to pay £30-40 just for a dipstick.
Last edit: 15 Oct 2015 19:01 by jim.
  • jim
  • Visitor
  • Visitor
15 Oct 2015 15:58 - 15 Oct 2015 19:26 #153714 by jim
Today's job was to change the front and rear axle oil. It's a job that often gets neglected. I knew the drain and filler plugs have had it so got these ready from bigjimny. I gave them a quick buff under the wheel and they look bling. I know it's a bit ocd but I want to be able to change all the oils each time I do the engine oil. I used some new copper washers for the filler plugs and blue loctite for the drain plug.
Well of course the filler plugs weren't coming out easily, good job I removed them first. So I dug out and used this heat gun for only 2mins on each drain plug and then they came off straight away Saving me a lot of hassle.
The oil was quite cloudy at the rear but fine at the front I used the correct api gl-5 80/90 and api-gl 4 75/90 in gearbox. The magnetic plug did catch a lot of swarf and gunk
Last edit: 15 Oct 2015 19:26 by jim.
  • jim
  • Visitor
  • Visitor
15 Oct 2015 16:03 #153715 by jim
The filler plugs were in a bad way.
  • Daniel30
  • Visitor
  • Visitor
15 Oct 2015 16:05 #153716 by Daniel30
Replied by Daniel30 on topic Galactic Jimny
Good job I have mine to do
Doesn't the drain plug come with a sealant in the thread already??
  • jim
  • Visitor
  • Visitor
15 Oct 2015 19:15 #153732 by jim
Thanks Daniel30, yes it comes on a few of the threads with some blue ptfe looking substance, as my drain plugs came out without me having to use heat or much effort I just reused them with fresh loctite and il keep the drain plug as a spare. Because they are tapered some people say they seal fine even without thread sealant but better to be safe than sorry.
The copper washers are 24x2mm I believe but I'll have to check, kirkynut advised me to get them off a reliable ebay seller.
Daniel30 wrote: Good job I have mine to do
  • Daniel30
  • Visitor
  • Visitor
15 Oct 2015 20:22 #153751 by Daniel30
Cheers for the info jim ;)
  • jim
  • Visitor
  • Visitor
16 Oct 2015 18:00 #153793 by jim
This is my first venture into dash cams so I went for the cheapest and smallest Halfords had and im quite impressed. All the wiring is neatly tucked away in the roof lining, door pillar trim and under the dash. I also picked up a double 12volt adaptor for a pound at the local car boot so I can run the satnav too.
  • jim
  • Visitor
  • Visitor
16 Oct 2015 19:05 #153796 by jim
New mats
  • Daniel30
  • Visitor
  • Visitor
16 Oct 2015 19:33 #153801 by Daniel30
Have you fitted them? If you have how do they fit?
  • jim
  • Visitor
  • Visitor
16 Oct 2015 19:58 #153804 by jim
Daniel30 wrote: Have you fitted them? If you have how do they fit?
I took a gamble on these daniel they are universal but the top can be trimmed/shaped around kick panels. I get so much mud and grass in the car it will make life easier to keep clean.
The dimensions of the front Mats are 70cm x 50cm I will post a picture up when they are in to see if they are worth having. They are £19.99 off ebay.
  • Smoggy
  • Visitor
  • Visitor
16 Oct 2015 21:25 #153808 by Smoggy
Replied by Smoggy on topic Galactic Jimny
Where did you get them from mate?
  • jim
  • Visitor
  • Visitor
16 Oct 2015 21:46 - 16 Oct 2015 21:49 #153810 by jim
Smoggy wrote: Where did you get them from mate?
These are the ones Smoggy they have a lip around them to catch the muck. I haven't recieved them yet but I'm sure they will fit. Much cheaper than suzukis rubber mat...cheaper by about £50 :ohmy:
Last edit: 16 Oct 2015 21:49 by jim.
Time to create page: 0.119 seconds
Powered by Kunena Forum
