Forum
Suzuki Jimny
My Jimny
Galactic Jimny
BigJimnyMeet 2024
Galactic Jimny
Daniel30
Visitor
11 Oct 2016 16:02 #173372
Yeah I know what you meen when I first got my Jim just the left speaker worked so you can imagine just one of those speakers working it was torture
jim
Topic Author
Visitor
11 Oct 2016 16:09 #173374
by jim
Daniel30 wrote: Yeah I know what you meen when I first got my Jim just the left speaker worked so you can imagine just one of those speakers working it was torture
I would have preferred to listen to the transmission and tyre noise than one standard jimny speaker.
Thank you received: 190
11 Oct 2016 19:00 #173395
by gusthegorilla
It's the little things that make such a big difference, jim, real confidence-boosters
I'm planning to live forever.....so far, so good !!
The following user(s) said Thank You: jim
jim
Topic Author
Visitor
11 Oct 2016 19:17 #173397
by jim
Thanks Gus, the jimny is used every day and I hope that if I look after it, it will look after me. I would love to do the big lift, snorkel mud tyres etc but I have to be realistic.
gusthegorilla wrote: It's the little things that make such a big difference, jim, real confidence-boosters
jim
Topic Author
Visitor
12 Oct 2016 14:45 #173438
by jim
Thanks to j999pre for sending me the two front rail caps that I broke when I removed the for spraying. I also got a spare centre cap for my spare.
jim
Topic Author
Visitor
13 Oct 2016 14:29 #173487
by jim
The new ignition coils arrived this morning. After fitting them I went for a long drive and sat in some traffic and fingers crossed there hasn't been any power loss. Accelerates like it use to again. I should have suspected they were on their way out when I had to replace the ignition leads a year ago. Being in the location that they are in, It must be the heat from the engine that eventually causes them to fail.
jim
Topic Author
Visitor
13 Oct 2016 16:56 - 15 Oct 2016 09:53 #173495
by jim
I wanted to repaint my calipers as they had a nice film of surface rust, but instead I just left this job to rust converter to do its magic. It's also easily wiped off unlike caliper paint.
Last edit: 15 Oct 2016 09:53 by jim.
jim
Topic Author
Visitor
15 Oct 2016 18:36 #173585
by jim
Today I fitted the 3 transfer box mounts. The 3 bottom nuts came off easily but I had to remove both the arms to use heat on the top 3. The decade old ones were softer and compressed more easily but they hadnt deteriorated as much as I had thought.
jim
Topic Author
Visitor
17 Oct 2016 12:39 - 17 Oct 2016 12:41 #173658
by jim
A bit of luxury for the cold mornings to come. A heated seat pad fitted neatly behind the waterproof seat overs.
Last edit: 17 Oct 2016 12:41 by jim.
jim
Topic Author
Visitor
02 Nov 2016 15:22 #174150
by jim
I received this bonnet protector today from Dave at Bits4vits. It's used, but with a quick clean and polish it it came up a treat.
Daniel30
Visitor
jim
Topic Author
Visitor
11 Nov 2016 13:46 #174505
by jim
This morning I removed the anti roll bar and wire brushed the flakey paint and corrosion off and started coating it in hammerite.
Then on go the new polybush ARB bushes and drop links.
Forum
Suzuki Jimny
My Jimny
Galactic Jimny
Time to create page: 0.135 seconds
