Galactic Jimny
- jim
- Visitor
- jim
- Visitor
- jim
- Visitor
- Visitor
- Thank you received: 360
- jim
- Visitor
Halford wrote: Cleaned up a treat, looks great
Thanks Halford, great to hear from you.
- jim
- Visitor
Daniel30 wrote: very nice very neat and tidy
Thanks Daniel30.
- 1066Boy
- Visitor
Is it a proper Suzuki accessory?
- jim
- Visitor
1066Boy wrote: Love that load liner. It would look a lot cleaner in the back of mine if I had one of those.
New they are about £180 but they come up second hand on gumtree free ads ebay etc. Probably better to remove all the back seats and board over like Gus has done.
- jim
- Visitor
I regularly jet wash underneath so there wasnt much dirt but I gave the surfaces a brush down then a wire brush down and a degrease ready for painting. I used Halfords zinc primer on the worse areas then applied the Hammerite Stone chip in Grey. The grey came out a bit darker than the cap showed, but it was quite a good match for the graphite Jimny. I prefer a lighter colour as its easier to see damage or cracks underneath.
The factory stone chip was still in good shape but there were plenty of areas without it.
While the rear wheel was off I investigated to exhaust knocking. The Tow-trust tow bars sits close to the to the rear sliencer and ocassionaly when theres enough movement it nocks. I did ask Tow-trust this before buying it but they hadnt heard of the issue. Dave form Bits4vits cut a V shape into his giving it clearance and stopping the knock.
Im not comfortable chopping bits off so I cured the knock by cable tying a ruber exhaust mount around it. I will get a metal tie as I think the heat from the exhaust might melt the plastic ones. if anyone else has the same problem its a quick fix.
I had to ditch the wheel locking nuts as the key for them had started to not fit poorly. It was fine when the tyre fitter used a pnematic tool but It would slip off when I used the breaker bar. Luckily the previous owner had kept the other wheel nuts.
- Thank you received: 28
Why didn't I think of that!
2012 Jimny Black. Totally standard (except for rear seat removal mod).
- jim
- Visitor
