Stateys 1999 UK Jimny... AKA CamoJimny (2014 - Present)
- Statey
- Visitor
Whats in the picture I did with about 100ml, got a 500ml can too I'm hoping that's enough but I could get some more if not!
Statey wrote: Will be putting some sort of stonechip top coat on top of 2 coats of primer,
Wow it goes a long way then! Ill deffo look into it for mine too as been wondering what do go for.
Their top coats look good although a little more expensive than others
- Statey
- Visitor
Did the tank in RCP as well and applied white stone chip to the bottom and black on top
And starting putting the final coat on the bits that I can't reach when the floors in
Boot hopefully be in soon
Sent from my Nexus 5 using Tapatalk
- Tadpole
- Visitor
- Statey
- Visitor
In the mean time not a lot happening just prepping the boot for the new floor, decided to give the front a tidy up.
My new favorite paint Buzzweld RCP
- OllieNZ
- Visitor
Looks like some great paintStatey wrote: I've decided on a body lift but just waiting on some funds to get it, I did have some old blocks from an old truck but there not the right size for the Jimny but I've used them on a temp basis to lift the body for better access and Ive done the hard work haha (also means I can prep and paint the body mounts)
I was tempted with the buzzweld but v limited info/reviews about it online. Therefore am tied between that an bilthamber who's rust treatment/protection is well regarded.
- Statey
- Visitor
Very true, I've spoke to Craig who runs Buzzweld and he passion he has for it just made my mind up, I've seen some of his tests he's run on thin steel and the results look great!minibbb wrote: Looking very smart!
Time will tell but I'm very happy with it so far!
- Statey
- Visitor
Slow going as I'm still healing from some stomach surgery but since I'm sorn... Might as well get some toys!
2inch lift kit with Steering spacer on the way!
- GraphicX
- Visitor
- Statey
- Visitor
I'll take a few pics tho
- Statey
- Visitor
I bought a Sand blasting Lance for a pressure washer and I have to say I'm impressed!
I blasted the rear of the car to make sure any loose rust and old sealant was removed.
Once I started I decided to do the axle as well
After painting in RCP this is what I was left with at the rear mount
After learning how to weld quickly haha I've fixed it all up and all mounts are now sound and rust free!!
I've covered all the welds RCP and then in Sikaflex to completely isolate them from the elements
With having the tank out it was ideal to get it painted all with RCP undercoat, I sealed all the joins on the floor as well as any older joins then covered the floor in Waxoyl, finally topped it off with a spray of Matt black top coat.
Need to finish the other shock and also get the tank back on!
Be back soon!
Sent from my SM-G935F using Tapatalk
