Project Elmo 2013 / Evil Elmo 2019
- jim
- Visitor
- Wuzie123
- Visitor
- Wuzie123
- Visitor
the top light is mounted on a smitybilt hawse braket its not wired up yet but will be run through the main beam switch like my old two were before i took them off...
still got lots sitting in my garage to get fitted and done like axel trusses, diff guards, but most important is going to be a front axel overhaul as my passenger side klngpins bearings have colapsed so it aint going anywhere for a while untill i can get that sorted...
Front axle overhaul Lol. Get used to those!
- Thank you received: 923
Must be like daylight when you turn all those lights on!
- Wuzie123
- Visitor
- Thank you received: 360
Doug any chance of a photo showing what's it's like where you've hacksawed the rear panel away as below
it looks like it makes some useable space
thanks
I also thought about getting a compressor and mounting it where you've mounted yours but may mount some speakers there to improve the sounds innit! I hate it when people say innit, so I've no idea why I decided to type it there. I must have come over all urban teenager yob like for a moment!
So we seem to think alike - albeit I'm sure you don't say innit, but then again neither do I usually. I think I'll have to take myself aside and have a word with myself about that. I used the term "Chizzle" the other day too!
- Wuzie123
- Visitor
thanks
hey i would take a pic for you but i am now in nigeria so dont have access to elmo just now.
If you look at the pannel you will see a peice that looks like it will pull off.... well inside there are about 12 screws holding it on to the main trim pannel... i undid them and used a angle grinder to trim off the top thinking it would give me a nice flat ledge to put the compressor on..................
WRONG when i put the bit back on the line i had followed left me with a slope going back into the tray area.... was a bit grumpy at that point but i thought i would give it a try anyway............
And loan behold it fitted and looks kinda good im going to go back in and clean up the edge where i cut it but im happy with the finished look
if you feel under the lip of the trim panel you will find the "angled" bit am talking about. and if i was to do it again i would go straight across where it dips down to leave a small pocket for "stuff"
hope that helps
- Wuzie123
- Visitor
kirkynut wrote: Would you mind taking a photo of the way you've mounted the light above the winch please mate? I've been eyeing up an LED light bar to go in the exact same place on mine!
its a smitybilt mount from the usa is you serch ebay for HAWSE LIGHT BRACKET it should come up... its about £50 posted if my memory is correct but a mate and i bought one each and saved on postage so it worked out at about £37 each. its a nice bit of kit but you will need longer bolts for your fairlead of hawse as it is about 5mm thick powder coated steel...
hope that helps
- darthloachie
- Visitor
www.amazon.co.uk/Smittybilt-Light-Bracke...irlead/dp/B00O1DUPD4
- Swifty
- Visitor
Wuzie123 wrote: Hey thanks
It was from a guy on here that sold it to me a couple months back... He said it was made for him by someone but they have stopped production now so I think it is almost a one of...
