Re:Re:Lumberjack Jimny
- woody woodpecker
- Visitor
thanks chris
Grant Munro wrote: Suzuki NZ introduced a pick-up version in May 2014 as part of the range, although it became special order as of October 2014. "Unique to New Zealand, the Flatdeck has an extended wheelbase that provides more load-carrying space. The deck measures 1,550mm by 1,550mm and has a carrying capacity of 300kgs. The lengthened chassis also improves weight transfer bringing more of the load weight in front of the rear wheels. The local engineering adaption called for a replacement driveshaft, but otherwise the Flatdeck is mechanically similar to the factory Jimny hardtop." Spare wheel is carried below the deck.
Yes that's what I had in mind when I made the image. My plan was to extend the chassis 400mm to allow for a 1.8 meter (6ft) bed- long enough to sleep in. In the UK, chassis modifications like that mean it would need to be inspected, which was a stumbling block for me but some other forum members are apparently familiar with the inspection process. The other issue is the load capacity- 300kg isn't enough for anything useful!
PM sentwoody woodpecker wrote: Hi Busta its nice to see someone else working there jimny in the timber trade. I sell logs down in devon and am very interested in how you delivery trailer works .Do you have any more pictures off trailer and is the bag you have on there a cubic metre bag , I think I might have to build one if you don't mind, and are willing to give me some dimensions.
thanks chris
- Grant Munro
- Visitor
- jim
- Visitor
Stuck in the soft wet peat here...
But with a bit or weight out of the trailer I could drive a few yards onto firmer ground and all was well.
- NineCherries
- Visitor
It looks like you work it hard too. What tyres are you running Busta?
I wonder if you'd benefit from a rocklobster to be able to pull that load with less strain on the clutch? If you use it alot the whine of a rocklobster might get irritating though.
Edit : The roof bars look like a good improvement!
- gaz3359
- Visitor
Tyres are BFG MT, 215/75. Running them at 15psi in the woods. Wide tyres on the trailer would be nice. A rocklobster would be good but to be honest 1st low is fine for all the work I do and I'm still doing a lot of road miles so I'm not sure if I'd cope with the whine. It's got a liana lump in it now which makes things easier.
