BigJimnyMeet 2024
× Tell us about your Jimny and post some pictures! Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Holmar's Jimny from Iceland
  • HolmarH
  • Visitor
  • Visitor
29 Apr 2015 17:35 - 29 Apr 2015 17:36 #143421 by HolmarH
Replied by HolmarH on topic Holmar's Jimny
TomDK wrote:
Busta wrote:
TomDK wrote: Lookes interesting with that V6. But isn't it very heavy compared to the G13BB engine ?
It is twice the power of the G13BB... I doubt that an extra 50-60kg makes much difference with those tyres.
I'm not interested in how much power this engine makes.
I'm interested in hearing about how it handles and what he's done to take the extra weight, springs, shocks and such.
I haven't changed the suspension yet, But I think this setup will be allright. I used to run 3X20 L jerry cans in front, and that worked well. No problems at all.
File Attachment:
Last edit: 29 Apr 2015 17:36 by HolmarH. Reason: Spelling :)
  • jimnydms
  • Visitor
  • Visitor
30 Apr 2015 08:37 #143443 by jimnydms
Replied by jimnydms on topic Holmar's Jimny
do you have any tips on the V6 conversion ? was it very difficult would you recommend this or was it a real nightmare to fit? did you use the Jimny gearbox or the vitara s ? cheers
  • HolmarH
  • Visitor
  • Visitor
30 Apr 2015 12:56 #143461 by HolmarH
jimnydms wrote: do you have any tips on the V6 conversion ? was it very difficult would you recommend this or was it a real nightmare to fit? did you use the Jimny gearbox or the vitara s ? cheers
I'm using the GV gearbox, GV T case (as a crawl gear) and a toyota T case behind.
No nigthmere while fitting it, only good dreams B)
Well.... tips.. I'll try to write something..
I removed the front cats, and have the large one remaining so I can run the engine without CEL.
You need a bodylift
Fuel lines had to be relocated
Of course custom engine bracket
Custom gearbox bracket
It is a really tight fit, I wanted to have the original radiator fan, and that works! But your hand does not fit between the engine and firewall. :P
A little cut in the firewall
Radiator moved a bit forward and down, front crossmember removed.. and another made
Wiring is not for everyone, but it is quite easy when you start.
I drilled another hole in the firewall, just for the engine harness.
I used the Jimny steering box, and GV steering pump.
Heater hoses are really hard to get to, I would suggest to relocate the input of the heater. ( Mine started leaking, and was very hard to get to and fix, but I managed to fix it without taking the engine out again) :silly:
I will post some pictures of the conversion later on.
Hope you understand my english, and that I can help someone out here :cheer:
  • jimnydms
  • Visitor
  • Visitor
01 May 2015 10:45 #143528 by jimnydms
You need a bodylift
Hope you understand my English, and that I can help someone out here :cheer:
Wow certainly an eye opener and some great tips there thank you for the information i understood your English just fine ! I will keep my eye out for the conversion pics
Thanks !!
  • HolmarH
  • Visitor
  • Visitor
21 May 2015 12:27 #144536 by HolmarH
File Attachment:
The donor..
File Attachment:
All out :)
File Attachment:
File Attachment:
Next up is the blue one
File Attachment:
File Attachment:
File Attachment:
File Attachment:
File Attachment:
G13BB vs H25A
File Attachment:
File Attachment:
Something has to be moved.
File Attachment:
The radiator had to come forward and down, with a refabbed crossmember
File Attachment:
LC 70 T case
File Attachment:
Towed out of its sleeping area!
File Attachment:
File Attachment:
More to come later on.
  • HolmarH
  • Visitor
  • Visitor
21 May 2015 12:54 #144544 by HolmarH
File Attachment:
File Attachment:
File Attachment:
File Attachment:
Motormounts
File Attachment:
File Attachment:
File Attachment:
Found some rust that needed repair.
File Attachment:
File Attachment:
Sandblasted
File Attachment:
2 T epoxy and blue
File Attachment:
Needed to fit the hydraulic clutch,
File Attachment:
File Attachment:
File Attachment:
File Attachment:
File Attachment:
Had to change the engine harness, it was on the back of the manifold, but had to put it down under because there was not enough space.
File Attachment:
Oil lvl
File Attachment:
Rad mounts and gearbox mount
File Attachment:
The cooland filling will be under the hood crossmember, so this was the solution, it came out of an XL7.
File Attachment:
Changed the timing chain tensioner
File Attachment:
File Attachment:
File Attachment:
File Attachment:
File Attachment:
21 May 2015 13:04 #144546 by Jezz
Replied by Jezz on topic Holmar's Jimny
Good work, I like that. Do you have a website address for where the extended arches came from?
It's been fettled just a tad.
  • OllieNZ
  • Visitor
  • Visitor
21 May 2015 14:10 #144554 by OllieNZ
Replied by OllieNZ on topic Re:Holmar's Jimny
Epic build! Looks sweet :)
  • HolmarH
  • Visitor
  • Visitor
21 May 2015 20:19 #144597 by HolmarH
Jezz wrote: Good work, I like that. Do you have a website address for where the extended arches came from?
Thanks, the website is
www.formverk.is
I cant see the jimny flares on their site, you will have to conact the company ;)
21 May 2015 20:38 #144600 by Halford
Replied by Halford on topic Holmar's Jimny
brilliant, thanks for all the effort in taking the pics B)
  • Solas
  • Visitor
  • Visitor
21 May 2015 20:43 #144603 by Solas
Replied by Solas on topic Holmar's Jimny
I take my hat of to you, thats amazing work/task! Well done!
21 May 2015 22:32 #144612 by Jezz
Holmar you are a star thank you. Keep up the good work. :)
Time to create page: 0.216 seconds
Powered by Kunena Forum
