- Forum
- Suzuki Jimny
- My Jimny
- JK's Jimny - Tasmania - Australia M18A, Manual with Auto Transfer and 30" KM2's
- jaykay
- Visitor
- Jonno_racing
- Visitor
- jaykay
- Visitor
Jonno_racing wrote: We need to do some wheeling together and get gricey along forcsone group pics
I agree
- MRocha
- Visitor
in your roof rack you have an awning fitted and what else?
- jaykay
- Visitor
MRocha wrote: your jimny is getting better, continue the good work.
Thanks mate, I also have a Rod tube on the other side usually - but its been taken off while I got repairs on the basket done.
- jaykay
- Visitor
After replacing the thermostat/ water pump and radiator cap the zook decided that was enough and blew the head gasket.
So time to fill everyone in on the Jim.
First this happened
Top radiator hose split lost coolant and cooked motor ( been over heating for a while now and was in the process of tracking it )
Coming close to the end of my holidays I needed to do something ASAP as the zooks my daily.
And I found this !
Then this happened
This is the result of trying to get the crank bolt out with a socket and a long handle - bench gave way
Got the motor in, missed a earth so had to trace back and find it.
Started her sat night n did a quick lap all was good.
Sunday this happened
O ring split on an injector ( used 1.3 instead of 1.8 injectors so just swapped them to the 1.8 )
Fixed, not viscus fan has died new ones on order !
- jonesyba420
- Visitor
- jaykay
- Visitor
have a few other mods to do before I do a trip.
Bullbar needs a chop chop and also going to extend my rear bump stops a bit.
It amazes me how you Aussies get out there so much and do it, I need to get off my backside and get out in the UK a lot more!
Was the viscous the cause of the overheating?
I have a scanguage in mine do I can see what the exact temperature is, the car's guage doesn't go up past half way until it's really hot!
- jaykay
- Visitor
I bought a WIFI OBD scan tool which I can connect to my iphone.
I watched the temprature on a 30min highway drive last night.
The coolant rose to 97-101 degrees then dropped back to around 90 degrees and stayed there which tells me everything must be working.
The 1.8 on the highway is awesome first time I've ever overtaken cars up hill !
My twin cam 1.3 Jimny never really goes above 97'c on a long uphill stretch of motorway in our summer, but my 1.5 Ignis Sport can go to 98-99'c in the summer if I'm on a long uphill climb on a motorway.
Have a check of your radiator too as I found mine was clogged and it sat at 104'c on a long uphill climb on a motorway. I couldn't clean it out enough to be happy so bought a new one to be on the safe side.
I would just keep an eye on it for a while and perhaps invest in a scanguage that can be permanently plugged in, so you don't have to think about connecting your phone interface bits. It's always there at a glance then to spot early on any trouble as you get to know what temperature it ought to be in differing circumstances.
Something positive came from you frying your 1.3 though eh!
- jaykay
- Visitor
- Forum
- Suzuki Jimny
- My Jimny
