BigJimnyMeet 2024
× Tell us about your Jimny and post some pictures! Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Re:Aussie 2006 Jimny - 4" lift, 30" BFGs, cool wheels
  • lukeyblunt
  • Visitor
  • Visitor
13 Feb 2011 14:19 #11472 by lukeyblunt
Replied by lukeyblunt on topic Re: Aussie 2000 Jimny
Just a quick 'heads up' those of you who sleep in your Jimnys..
I know of a few people who have had to replace the rubber trim around door /window frames because of the condensation - from all the breathing in a confined space.
Caravans, on the other hand, have reasonable ventilation. :huh:
Make sure you open windows just a little to avoid the same troubles. - you may, however, need another blanket !
  • zukenutter
  • Visitor
  • Visitor
13 Feb 2011 20:59 #11502 by zukenutter
Replied by zukenutter on topic Re: Aussie 2000 Jimny
thanks for that heads-up. I have weather shields fitted to both doors so I can keep the windows open without getting wet. Here is Queensland cold isn't an issue. :D
  • zukenutter
  • Visitor
  • Visitor
07 May 2011 08:14 #15998 by zukenutter
I bought and received an ORA transfer swap kit recently. Today I set up the case ready for installation using the Big Jimny instructions. Very easy to install. I still need to find a front shaft before the swap can take place.
  • renard38
  • Visitor
  • Visitor
07 May 2011 16:36 #16015 by renard38
Replied by renard38 on topic Re: Aussie 2000 Jimny
it's a 4.16 transfert box or 6.1??
  • zukenutter
  • Visitor
  • Visitor
07 May 2011 19:21 #16019 by zukenutter
renard38 wrote: it's a 4.16 transfert box or 6.1??
Just standard 1.3 gears, Non VVT gearbox ix going in to replace the lower geared VVT box and the lower 4.3 diff ratio found in the VVT Jimny. About 16% lower than stock. I run 235/75R15s so it should end up about 6% lower than stock if my calculations have been correct.
  • zukenutter
  • Visitor
  • Visitor
22 May 2011 22:52 #16803 by zukenutter
Started the gearbox and transfer swap on Saturday, got everything apart except for the gearbox which is unbolted and ready to come out. Sunday my nephew Jack came around to give me a hand putting it all back together.
Transfer out. I removed the middle section of the exhaust to help the gearbox clear everything.
I forgot to drain the oil and made a mess when I pulled the jack shaft.
Shifter boot is unbolted
Jimny electric on right
Jimny electric on Left
The complete driveline that's going in
Back into it Sunday. Pulled the gearbox, compared it to new and realised that there was going to be some shift mechanism issues. As it turned out the rear gearbox mount is different so I used the Mark III Jimny mount but had to re-drill a couple of holes.
Both gearboxes are very different from the bell back.
Mark III back, Mark II front
Reverse sender plug wasn't compatible so RC parts to the rescue.
Transfer mounted :D
I need to make a mount for the shifter mech.
The only difficult part to this swap is the fact that I'm also swapping the gearbox. Mounting of the actual transfer has been a breeze. Now fingers crossed the box and case have no internal issues.
  • Monkey
  • Visitor
  • Visitor
23 May 2011 09:10 #16818 by Monkey
Replied by Monkey on topic Re: Aussie 2000 Jimny
Looking good mate!
  • renard38
  • Visitor
  • Visitor
23 May 2011 14:56 #16851 by renard38
why did you change the rear driveshaft??? :huh: ( I have the same at the beginning with my new transfert box 4.16 )
  • zukenutter
  • Visitor
  • Visitor
23 May 2011 19:09 #16869 by zukenutter
Without going and measuring them, I think the Original shaft is too short. The replacement is an SJ front shaft.
24 May 2011 07:35 #16887 by Obarno
Replied by Obarno on topic Re: Aussie 2000 Jimny
With the ORA kit the original Samurai transfer box rear flange is used and therefore the Jimny prop will not bolt up to it as it is the wrong shape for a CV prop, and also its too short. With the Measson kit you get a new rear output flange which allows the original Jimny prop to bolt straight to the Samurai transfer box and it also corrects the propshaft length issue.
On my rear prop I had an ali spacer/adaptor made that bolts to the Sammi flange but takes an original Jimny prop.
  • zukenutter
  • Visitor
  • Visitor
24 May 2011 19:13 #16914 by zukenutter
Obarno wrote: With the ORA kit the original Samurai transfer box rear flange is used and therefore the Jimny prop will not bolt up to it as it is the wrong shape for a CV prop, and also its too short. With the Measson kit you get a new rear output flange which allows the original Jimny prop to bolt straight to the Samurai transfer box and it also corrects the propshaft length issue.
Much better explanation than my lame effort. Cheers
  • zukenutter
  • Visitor
  • Visitor
17 Nov 2011 23:07 #25992 by zukenutter
Have been doing some paving in a townhouse courtyard, filled the trailer with soil and concrete, went to the tip and dumped the rubbish today. For those that think a Jimny won't pull much weight here's the weigh bridge docket. Note the Gross Weight.
As soon as I dumped the 480kg (Nett waste weight) I went and loaded up 500kg of 10mm Concrete mix and three 20kg bags of cement + tools.
Yeah my gears do help, I don't dump the clutch or ride it, she'll happily pull all day long. Wish I could say the same about the mrs.
This will be handy on the job. I plan to set it up so it can be used front or rear.
Dynamic Power 12V 3000LBS / 1361KG Electric Winch With Wireless Remote
Quick Overview
- Super Big Power up to Max. 2400W, 30Kpa
- Powerful 1361kg Pulling Power (will double that with a snatch block, plenty for my needs)
- Portable, with Built-in Carrying Handle and Quick-Attach Mounting Plate
Went out on the 2nd Jimny Driver's Day, camped overnight.
Time to create page: 0.158 seconds
Powered by Kunena Forum
