BigJimnyMeet 2024
× Tell us about your Jimny and post some pictures! Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Re:Aussie 2006 Jimny - 4" lift, 30" BFGs, cool wheels
  • zukenutter
  • Visitor
  • Visitor
23 Apr 2014 23:31 #113154 by zukenutter
piratematt wrote: Amazing truck mate! This series of posts was part of what inspired me to get the Jimny, with what can be done to them. We spend a fair bit of time in and around Perth so might need to get a second Suzuki to leave over there!
Matt
Cheers Matt, glad you've enjoyed the read and I hope you enjoy your Jimny as much as we do.
  • zukenutter
  • Visitor
  • Visitor
27 Apr 2014 10:01 #113458 by zukenutter
I know you guys like to see a bit of Aussie countryside.
Had a weekend in Stanthorpe, climbed the Pyramid in Girraween National Park.
  • jonesyba420
  • Visitor
  • Visitor
27 Apr 2014 10:11 #113461 by jonesyba420
Nice pictures buddy.
  • zukenutter
  • Visitor
  • Visitor
02 May 2014 23:35 #114004 by zukenutter
I bought an M18A VVT two weeks ago, started prepping it ready to swap. Really looking forward to the huge jump in HP and torque.
Liana oil pick up on the left, Jimny on the right
Liana dipstick left, Jimny on the right
Engine seems pretty clean as it should with 68,000 kms
Jimny oil pick up in place
All set except for idle control thingy and back of water pump, these will be scrounged from the 1.3 when it comes out. Also I need to drill the Liana rocker cover to accept the Jimny dipstick and blank off the Liana dipstick hole.
So this weekend I'll prep the rocker cover and fit the Jimny crank pulley which I have a spare of.
  • zukenutter
  • Visitor
  • Visitor
09 May 2014 09:30 #114576 by zukenutter
1.8L is in and running. Really happy with the way it's running and the increased acceleration and torque, towing the camper will be so much easier. My Jimny will be going through some changes with more of a leaning towards touring.
  • jonesyba420
  • Visitor
  • Visitor
09 May 2014 10:01 #114579 by jonesyba420
bet it goes like a rocket lol!!
  • zukenutter
  • Visitor
  • Visitor
09 May 2014 10:20 #114581 by zukenutter
It's fun being able to tear away at traffic lights. My favourite test hill showed just how good it is. With the 1.3 it was a third gear climb to the top, now it accelerates up the hill in fifth gear... Made me smile.
  • jonesyba420
  • Visitor
  • Visitor
09 May 2014 11:59 #114591 by jonesyba420
Will be alot of fun in the wet ;)
  • zukenutter
  • Visitor
  • Visitor
09 May 2014 21:19 #114666 by zukenutter
I will have to be careful although it still has smooth and controllable acceleration
  • Nox
  • Visitor
  • Visitor
10 May 2014 18:06 #114746 by Nox
Did you chip it at all or only swapped the engine?
Did you use the M13A sump and ECU?
Injectors?
Seriously nice Jimny that.
Would love to do a M18A
Wonder how well a M16A would work? More available here. If I go M18A I'll have to import.
  • zukenutter
  • Visitor
  • Visitor
10 May 2014 21:12 #114779 by zukenutter
Just swapped the engine. It's reasonably straight forward but you need to be confident and have a good array of tools and an extra pair of hands. All up it's a good 2 days work for two people. It runs great on the 1.3 ECU, has 1.8 injectors with 1.3 fuel rail, Jimny sump, pick-up and oil filter holder. I had to remove a dowel from the engine so the bell housing would mate up, You also need to either drill a new dip stick hole in the rocker cover or use the Jimny rocker cover (I used the 1.8 rocker). Some guys here are using the 1.8 throttle body but it wasn't working on mine so I'm using the Jimny TB for the time being.
Any M motor should work but the selection should be based on the current engine, e.g.; if you have a VVT Jimny I think you should use a VVT donor, if you don't have VVT you should use a non VVT engine… I think! ECU compatibility.
Looking at the specs of the different M motors the 1.5 and 1.6 have high compression ratios compared to the more 4WD friendly 9.5:1 (1.3) and 9.6:1 (1.8) ratios.
This is not a job I'd want to have to do again in a hurry but I'm very happy with the outcome.
I should add that if it wasn't for a great how-to guide done by one of the guys here in Aus I wouldn't have done this.
Wiki M motors
While I had the bumper off I got a clearer pic of how I support my anti-sway bar once it's unbolted from the chassis
  • ATW1980
  • Visitor
  • Visitor
19 May 2014 19:55 #115767 by ATW1980
Love your thread!! Awesome!!
Time to create page: 0.137 seconds
Powered by Kunena Forum
