Vehicles (17 Jan 2019)
You can now add the vehicles you own to your profile as little icons that appear in your profile and alongside your posts.
This is a bit of an experiment. Take a look under the "REWARDS" menu across the top of the screen for the vehicles "ADD/MODIFY" option.
Let me know how you get on.
Aussie 2006 Jimny - 4" lift, 30" BFGs, M18a VVT
- lukeyblunt
- Visitor
I know of a few people who have had to replace the rubber trim around door /window frames because of the condensation - from all the breathing in a confined space.
Caravans, on the other hand, have reasonable ventilation.
Make sure you open windows just a little to avoid the same troubles. - you may, however, need another blanket !
- zukenutter
Topic Author
- Gold Boarder
- Thank you received: 17
SUZUKI - Way of life!
- zukenutter
Topic Author
- Gold Boarder
Jimny JLX 2004, ジムニー JB43
préparation Méasson: suspension + 7 cm, body + 7 cm, colonne direction rallongée, boite courte 4.16 avec blindage, coquilles de ponts, tirants de ponts jimnybits avant avec caster corrigée
pneux BF goodrich mud terrain 235-75-15
- zukenutter
Topic Author
- Gold Boarder
renard38 wrote: it's a 4.16 transfert box or 6.1??
Just standard 1.3 gears, Non VVT gearbox ix going in to replace the lower geared VVT box and the lower 4.3 diff ratio found in the VVT Jimny. About 16% lower than stock. I run 235/75R15s so it should end up about 6% lower than stock if my calculations have been correct.
- zukenutter
Topic Author
- Gold Boarder
Transfer out. I removed the middle section of the exhaust to help the gearbox clear everything.
I forgot to drain the oil and made a mess when I pulled the jack shaft.
Shifter boot is unbolted
Jimny electric on right
Jimny electric on Left
The complete driveline that's going in
Back into it Sunday. Pulled the gearbox, compared it to new and realised that there was going to be some shift mechanism issues. As it turned out the rear gearbox mount is different so I used the Mark III Jimny mount but had to re-drill a couple of holes.
Both gearboxes are very different from the bell back.
Mark III back, Mark II front
Reverse sender plug wasn't compatible so RC parts to the rescue.
Transfer mounted
I need to make a mount for the shifter mech.
The only difficult part to this swap is the fact that I'm also swapping the gearbox. Mounting of the actual transfer has been a breeze. Now fingers crossed the box and case have no internal issues.
- Monkey
- Visitor
- zukenutter
Topic Author
- Gold Boarder
On my rear prop I had an ali spacer/adaptor made that bolts to the Sammi flange but takes an original Jimny prop.
Manual VVT, 2 1/2" lift, ORA castor corrected arms, 2" ORA body lift, Rockwatt transfer box, Uprated front shafts & CVs ERM , ARBs back & front 3.9 diffs, 6 point cage, ORA winch bumper - Superwinch EP9, ORA rear bumper, ORA axle truses, Diff guards ERM , TBR tank guard, Snorkel, Kumho KL71.
- zukenutter
Topic Author
- Gold Boarder
Obarno wrote: With the ORA kit the original Samurai transfer box rear flange is used and therefore the Jimny prop will not bolt up to it as it is the wrong shape for a CV prop, and also its too short. With the Measson kit you get a new rear output flange which allows the original Jimny prop to bolt straight to the Samurai transfer box and it also corrects the propshaft length issue.
Much better explanation than my lame effort. Cheers
- zukenutter
Topic Author
- Gold Boarder
As soon as I dumped the 480kg (Nett waste weight) I went and loaded up 500kg of 10mm Concrete mix and three 20kg bags of cement + tools.
Yeah my gears do help, I don't dump the clutch or ride it, she'll happily pull all day long. Wish I could say the same about the mrs.
This will be handy on the job. I plan to set it up so it can be used front or rear.
Dynamic Power 12V 3000LBS / 1361KG Electric Winch With Wireless Remote
Quick Overview
- Super Big Power up to Max. 2400W, 30Kpa
- Powerful 1361kg Pulling Power (will double that with a snatch block, plenty for my needs)
- Portable, with Built-in Carrying Handle and Quick-Attach Mounting Plate
Went out on the 2nd Jimny Driver's Day, camped overnight.
