BigJimnyMeet 2024
Re:Re:Re:Problems with BigJimny!
- Thank you received: 923
09 Nov 2019 07:45 - 09 Nov 2019 07:48 #215498
Replied by X8GGY on topic Problems with BigJimny!
Looks like the crown wheel bolts have loosened, rattled out, and been thrown into the gear’s teeth, that’ll be the bang you heard...
They should have been loctite’d in and torqued to spec’... who built the Diff.?
From the photos it looks like the ARB’s case / crown wheel carrier has a slight chew to it, but should still be okay...?
If it was me... I’d pop the “new / spare’ Diff you now have into the back axle and rebuild the axle and that will get you mobile again..
Clean and test the ARB with the airline from the compressor and check it still locks up alright...
Then get another rear Diff and combine that and your ARB at your leisure...
I’d use the existing axle casing as that’s already drilled for the air connection...the new crown wheel and pinion would then need building around the ARB, the copper feed pipe looks to be undamaged? So you just need either the confidence to strip and rebuild it yourself? Or a specialist garage / gearbox kind of place... I used a local Land Rover garage once that was used to off-road vehicles...
HTH
Dave
HTH
Dave
Last edit: 09 Nov 2019 07:48 by X8GGY.
09 Nov 2019 15:49 - 09 Nov 2019 15:52 #215515
Replied by mlines on topic Problems with BigJimny!
Thanks Dave,
Thats exactly the plan, use "your" diff straight into the JImny to keep us going so that we have it running for the two days of "Jimny only" weather we get each winter,
Get another 3.9 diff to act as a donor and have unpressured rebuild of the ARB diff over the winter, learning on the way. However yours was the only properly priced diff on ebay so will wait for another to come up. I dont believe in paying too much for 3.9 diffs.
Last edit: 09 Nov 2019 15:52 by mlines.
09 Nov 2019 17:05 #215516
Replied by Riccy on topic Problems with BigJimny!
James Priestly might have one, or look up a fella called Cliff Totney in Hamilton, nr Edinburgh who usually has loads of jimny parts and posts
I have a paper copy of the ARB installation instructions from mine if you need them (but are probably available online too). Not difficult things to install really.
The following user(s) said Thank You: mlines
09 Nov 2019 17:14 #215517
Replied by mlines on topic Re:Problems with BigJimny!
Thanks riccy,
I also have the instructions already.
What I am also looking at is the workshop manual for the Jimny and there is a lot about setting up the end float, shimming and the preload which concerns me
09 Nov 2019 18:12 #215519
Replied by Riccy on topic Re:Problems with BigJimny!
Most of that is to do with the pinion gear. If you have a good donor diff then there is no need to touch any of that.
Get the locker out and asses the damage first, but its probably OK and the shafts would have stopped any large parts entering the locker, meaning cleaning and maybe get it on a lathe to tidy up the outside gouge marks hopefully.
The locker setup you need to do is the backlash and bearing alignment. Not that difficult with some fairly cheap tools
one of these for setting the backlash:
www.machinemart.co.uk/p/cm220-dial-test-indicator/
and a magnetic mount of some sort for it:
www.machinemart.co.uk/p/et113-125mm-mini-magnetic-stand/
plus a torque wrench is about all is needed other than standard tools and some marker paint
Maybe add in a 1/4 NPT tap to drill & tap the casing of the new donor diff for the ARB airline, saves messing about with the pinion if thats good on the donor diff...
Time to create page: 0.126 seconds
