BigJimnyMeet 2024
1999 Jimny JLX Blown Head gasket
- Reason2doubt
- Thank you received: 100
30 Nov 2019 11:52 #216081
by Reason2doubt
Replied by Reason2doubt on topic 1999 Jimny JLX Blown Head gasket
Sorry you are having so many troubles - keep us up to date Be good to know how you get on seeing as I went through this not too long ago.
I do recall getting my head skimmed with the new gasket so that sounds like a solid plan.
30 Nov 2019 14:44 #216088
by kirkynut
Replied by kirkynut on topic 1999 Jimny JLX Blown Head gasket
I cannot believe he didn't skim the head! The block should be flat though but it sounds like someone with more knowledge than I has found it's not.
Skimming both will increase the combustion ratio quite a bit but this could be taken up with a thicker gasket.
Payen gaskets are supposed to be the best aftermarket ones.
The head bolts need to he torqued down in a set order and in stages. Otherwise the head will warp. Surely the previous guy did that right?
- Owl
- Visitor
01 Dec 2019 07:51 #216107
by Owl
Replied by Owl on topic 1999 Jimny JLX Blown Head gasket
Hi KirkyNut , Its hard to know whether it was skimmed in the first place, seems like the proper thing to do if your doing a engine recond would be to skim the head and block mating surface. I did have an overheating episode, popped the top hose, so that definitely either caused or exacerbated it.
I don't like the lies of them saying there is / was nothing wrong, They agreed to take it as a warranty issue, (which I found means nothing) so at the time I didn't test, tamper or repair anything as the warranty becomes void. But now that I know they don't honour warranty it up to me to try and salvage it .
I have a mechanical background (Industrial and Outdoor power equipment), so did the CO2 chemical test and radiator / cooling sys pressure test both of which highlighted a problem we call a blown head gasket which can be a generic term for a number of problems in that area. I was losing coolant ,no external leaks.
The head is being assessed at a head reconditioning place, they will do the usual checks and skim it if its a good candidate, He said he has seen a couple Jimnys with cracked heads which appeared around those top welsh plugs on the head. Theres 3 there from memory. I looked those over but couldn't see any cracks which is positive . To confirm it after taking rocker cover off , can do a pressure test and watch those areas for any coolant leakage. I'll wait for the prognosis from the expert next week.
- Owl
- Visitor
01 Dec 2019 07:58 #216108
by Owl
I should have mentioned I did a number of checks with a flat rule and feeler gauge on the block mating surface , and found there I could easily slip 0.06" through around the centre of the block face. The mechanic said he might be able to remove some of the high spots by hand but I'll wait for his opinion when he measures it up.
01 Dec 2019 08:23 #216110
by kirkynut
I think I'd prefer to have the block machined flat. You know it's proper flat then and 0.06" is nothing in terms of how the car will run with it removed but enough to cause sealing issues.
- Owl
- Visitor
01 Dec 2019 09:53 #216114
by Owl
I agree KirkyNut, Would be nice to have a machined block surface which means engine removal and dismantling...….again. I'm not going there for this one. Project ends there. Engine has been out twice and gearbox out 3 times in 2019. Ill have to suck it up as an expensive fail.
- Thank you received: 1759
01 Dec 2019 11:09 #216115
Replied by Lambert on topic 1999 Jimny JLX Blown Head gasket
Like I said earlier drop in a 1.6 out of a liana.
Time to create page: 0.099 seconds
