Forum
Suzuki Jimny
Jimny Technical
Re:Constantly flashing amber ABS light
BigJimnyMeet 2024
mickt
Visitor
02 Oct 2019 14:51 #214181
by mickt
I have just had a quick read of the workshop manual on the ABS flashing light problem and one thing it does mention is that the ABS module monitors the voltage to the stop light bulbs. It might be worth a check of these bulbs as a bit of rust on their contacts could cause an intermittent fault.
Riccy
Offline
Banned
J999 MNY Bashing around Carlisle
Thank you received: 554
02 Oct 2019 17:03 #214188
mickt wrote: I have just had a quick read of the workshop manual on the ABS flashing light problem and one thing it does mention is that the ABS module monitors the voltage to the stop light bulbs. It might be worth a check of these bulbs as a bit of rust on their contacts could cause an intermittent fault.
That gave me an issue when swapping to LED rear lights. I found that switching on the side lights or headlights set off the ABS light. Also the indicators flashed too fast. Needed a resistor on the both brake and indicator lights to sort it out.
KT53
Topic Author
Visitor
08 Oct 2019 18:33 #214488
by KT53
Thank you all. My Jimny booked for an MOT next week, now the flashing ABS light is out. The local garage checked and cancelled the warning light without charge. The warning light has not re-occurred, so don't know why it happened, but all seems well at the moment. Thanks again for your support.
Forum
Suzuki Jimny
Jimny Technical
Time to create page: 0.076 seconds
